Leaky Cowl?!
Old Sep 16, 2007 | 05:45 PM
zagadka's Avatar
zagadka
Leaky Cowl?!
After washing my car, or recently when its raining and the wipers are going, i get some drips of water onto my clutch foot. I'm thinking its coming from the cowl- but why?
Anyone else have this problem? Its not a huge, gushing leak, but definitely enough to be annoying and make for a wet sock. And no one likes wearing wet socks!
Old Sep 16, 2007 | 06:01 PM
rhawth99's Avatar
rhawth99
Do you have a sunroof? If yes, there is a drain line that runs down into the A pillar. Sometimes they get plugged or disconnected.
Old Sep 16, 2007 | 06:32 PM
zagadka's Avatar
zagadka
Yup- I do! That would make sense! Where can I find said drain line?
Old Sep 17, 2007 | 01:11 PM
djam43's Avatar
djam43
There is four drains in your sunroof assembly, I would suggest that you return to the dealer for warrenty as there is probably a blockage or disconnect,
Old Sep 17, 2007 | 03:28 PM
jascooper's Avatar
jascooper
There are also some small holes on the cowl that seem to be drains. They are small and probably easily clogged. Do you park under trees a lot? I'd check them too.
You might try threading a thin wire (carefully) down the holes. Run water over the holes to see if they indeed drain.
Old Sep 18, 2007 | 04:45 AM
zagadka's Avatar
zagadka
sadly, warranty has expired so its a DIY project now.
jascooper, i DO park under a choke cherry tree that had these stupid berries that fit ever so perfectly into the circular holes of the cowl. and since you mentioned that, i never had this problem until i had to park under that wreched tree!!! i'll bet they're clogged with choke cherries- ugh!
WhinyR53
Sep 30, 2015 07:36 AM
YoloSapien
Sep 25, 2015 07:12 AM
CooperT
R60/R61 Stock Problems/Issues
Sep 22, 2015 12:54 PM
Aug 7, 2015 05:56 AM
