Engine Diesel Sound
Old Aug 18, 2007 | 04:48 AM
korby's Avatar
korby
Engine Diesel Sound
Not the normal clicky clack sound .On my trip to Shelter Cove I was parked on an incline over night ,in the morning it was in the 40's and I was following my uncle in his car out of Shelter Cove . He took off , I started up and the engine was making a sound like it had no oil in it .It's the same noise that was posted here before but the post is now gone.After a minute it stopped and ran normal.I have not read about this problem recently .Does anyone else still have this problem ?
Old Aug 18, 2007 | 09:13 AM
dirkinoff's Avatar
dirkinoff
Mine has made a sound "Rattle,Clacking" a few times at idle and gets worse between 1200 and 1500 RPM, I beleive it is a sticky tensioner, If I blip the throttle to boost the oil pressure it goes away and does not return.
Old Aug 18, 2007 | 10:10 AM
lhoboy's Avatar
lhoboy
I think this is the thread you were looking for:https://www.northamericanmotoring.co....php?p=1692623
Old Aug 18, 2007 | 10:17 AM
dirkinoff's Avatar
dirkinoff
Thank you for the link to the thread but it looked like those were all S/C minis. Mine is a 07 MCS with about 2000 miles on it. Its been about 400 miles since it did it, I am pretty sure it was a tensioner. I keeping my fingers crossed that its gone for good.
Old Aug 18, 2007 | 03:08 PM
korby's Avatar
korby
http://s161.photobucket.com/albums/t...Outsidecar.flv Here's the sound incase somebody has'nt heard it yet .Or go to MINI 2 forum 2007 faults and fixes and hear more .
Old Nov 30, 2008 | 07:32 AM
charger's Avatar
charger
My Wifes 2005 Mini S with Dinan S2 has been making the same diesel noise but only at idle. Sometimes not all. Depends I think on how long it idles.
She has run hot twice due to a very very slow 6 month water leak. I say run hot because thats what the gauge says. However when I checked the engine nothing was hot to the touch. Hoses, radiator, even top of head.
Old Nov 30, 2008 | 07:36 AM
Ian Venieri's Avatar
Ian Venieri
Do a search for the PUMA # that addresses the issue by replacing the belt and tensioner. Noise goes away.
Old Nov 30, 2008 | 08:47 AM
sequence's Avatar
sequence
The problem this thread refers to is with the second gen "Prince" engine's cam chain tensioner Check the stock problems/issues thread on the first gen cars for info on yr 2005. When I had mine it never dieseled at startup, just ran crappy the first couple of minutes.
Old Jan 13, 2009 | 05:37 PM
gotguitar's Avatar
gotguitar
Hi!
My Dealer (Mini of Universal City) has confirmed it's the tensioner. They'd ordered the part late last week and it should be in tomorrow.
2007 Mini Cooper S - 6spd
Old Jan 13, 2009 | 09:27 PM
guidmini's Avatar
guidmini
high idle test
Hi Mini tech here, sometimes there is a oil pressure loss in the timing chain
tensioner. What you can do and works @ times. Is run the engine @ 1500-1800 rpm's for 5 minutes then let idle for a few minutes repeat this step up to 5 times. in most cases this will create enough pressure built up in the chain tension and the noise will dissipate. if not then it will need a updated
tensioner. Rem !!!!ALWAYS CHECK THE OIL LEVEL 1ST. some times I would see newer car with insuffceint oil fill from the factory. I suggest doing this I know alot of customers are not veryclose to there dealers. thats why I said
try this 1st. REM THIS ONLY APPLIES TO THE R56 COOPER S THE N14 ENGINE not the normal cooper.
David.R53
Sep 1, 2015 06:49 PM
Zettinger
Aug 25, 2015 04:04 PM
makg
Aug 21, 2015 02:49 AM
damncajun
Aug 17, 2015 08:25 PM
