Wiper Smudge problem
Old Aug 3, 2007 | 12:48 PM
CeeTee1's Avatar
CeeTee1
I have had my MC for 4 months now and for some reason my wiper blades are leaving smudge marks when I use them in the rain. Has anyone had this problem? What could be causing this to happen to 4 month old blades?
Old Aug 3, 2007 | 01:57 PM
subieworx's Avatar
subieworx
These wipers suck!!! Car is 2 months old and at not even 2000 miles and the wipers are dead. "Cleaning" the windshield with them actually makes it more difficult to see out of.
Old Aug 3, 2007 | 02:58 PM
moeman's Avatar
moeman
have you tried to clean the blades themselves?
sometimes this helps....
Old Aug 3, 2007 | 03:29 PM
oldsbear's Avatar
oldsbear
I wipe the blades when I wipe the windshield and have no problem. Also use Rain-X, so the wipers often aren't even needed. A side benefit of the Rain-X is that the bugs don't stick so hard.
Old Jan 16, 2008 | 03:27 PM
Twin Turbo's Avatar
Twin Turbo
I had the same problem till i replaced them with the REFLEX WetTec.
I find the spray jets don't spray in the right place plus the wipers are a poor design.
Twin Turbo
Old Jan 16, 2008 | 04:40 PM
daffodildeb's Avatar
daffodildeb
Get free wipers. It's part of your service plan.
I do agree, the wipers aren't good. I got them after only about 6 months, and that's unusually early for my cars. Plus, I had a thin layer of rubber on the far left end of the stroke. Never had that before on anything I've owned.
Old Jan 20, 2008 | 02:08 PM
Krut's Avatar
Krut
Try wiping some rubbing alcohol on the edges of the blade - that will prolong their life and make your windshield wipers work more effectively.
Old Jan 22, 2008 | 02:34 PM
giantjoe's Avatar
giantjoe
Re-aim your washer nozzles. All you have to do is take a pin to them and aim, test, aim, test. You'll find the sweet spot.
Old Jan 22, 2008 | 02:52 PM
daffodildeb
One problem with doing this--washers at speed aim differently from washers at subdivision speeds...
Old Jan 22, 2008 | 02:58 PM
rockridge's Avatar
rockridge
Has anyone tried the wiper product from 303?
http://www.303products.com/tech/inde...Product_ID=435
Old Jan 22, 2008 | 06:23 PM
07chilired
My dealer said that you can only get free wiper blades under the service plan once every 6 months.....which stinks because they don't last that long
Old Jan 22, 2008 | 06:30 PM
Blue Skies 05's Avatar
Blue Skies 05
Michelin Radius Wipers
I found that the OEM blades started to leave black marks after about 6 months, regardless of whether or not I wiped down the blades with alcohol, etc. I also keep Rain-X on the windows.
Last month I replaced them with Michelin Radius Wiper Blades (Wal-Mart). A marvelous replacement in our rainy, blustery WA weather.
I suppose I could have gone to NW MINI for "free" replacements, but "free" doesn't equal quality IMHO.
Old Jan 24, 2008 | 09:14 AM
opass's Avatar
opass
Mine does not work very well after 2-3 months. The problem is the quality of the rubber. Time for after market units.
Old Jan 24, 2008 | 09:53 AM
benfica09's Avatar
benfica09
replaced mine with the Valeo Ultimate 900
http://www.valeowipersusa.com/index.asp?pgid=19
night & day difference.
Old Jan 24, 2008 | 10:44 AM
lacning74's Avatar
lacning74
Which model/size? Easy to replace?
Old Jan 24, 2008 | 01:41 PM
herbie hind's Avatar
herbie hind
also ; keep the heat to the windshield to a minimum once it's clear . i find it gets so hot the washer fluid dries while wiping leaving a smudge . if i keep the temp down it improves greatly .
Old Jan 24, 2008 | 01:57 PM
daffodildeb
Amazing! i've had no problems other than routine replacement at about 8 months. Just goes to show "Your mileage might vary."
Old Jan 24, 2008 | 03:32 PM
Capt_bj's Avatar
Capt_bj
Clay your glass
Yes, you heard me right.....
Take your left over clay bar and clay your glass.... You'll be amazed how much crud comes up..... Smooth glass equals better wiper performance
I would suggest replacing OEM blades with almost anything but I got poopoo'd about such a major modification by a "stock" **** a few weeks ago
I ran PIAA for a while but haven't found them better than simple ANCO, replaced as needed...AFTER I clayed the glass.....
Old Jan 25, 2008 | 09:09 AM
jw34's Avatar
jw34
Where I really notice an issue is when I have crud on the window and use the washers. I get lost of nice streaks. I've cleaned the blades and clayed the glass. I'm going on 4 months.
Old Jan 26, 2008 | 05:58 AM
rockridge's Avatar
rockridge
I agree with the captn. Claying you glass makes a huge difference in wiper quality.
Old Jan 26, 2008 | 07:55 AM
giantjoe's Avatar
giantjoe
OK I'll bite, what the crap is claying your glass?
Old Jan 26, 2008 | 01:14 PM
Msteadman's Avatar
Msteadman
Just installed Rain-X Latitude wipers on my MCS yesterday. Huge improvement and as an added bonus they look sweet.
I've also heard very good things about Bosch ICONs.
Old Jan 26, 2008 | 01:31 PM
Capt_bj's Avatar
Capt_bj
Clay Bar
You'll see in the 'detailing' forum, many discussion of 'claying' a car. Using a bar of clay....yes clay...and a lubricant (no snide remarks) one rubs down the surface and removes many impurities and general ruff stuff fm the paint (clear coat). It is the way to get the babies behind smooth finish. The clay is sort of a super fine polishing compound and the binding agent of the clay pulls away what the abrasive knock loose....the result is a very very smooth finish, ready for your coat of wax. Run your hand over a car a couple of years old - even one waxed regularly and you'll (probably) feel some ruffness. Clay that puppy and in goes to smooooooth. (My next door neighbor bought a new car and told me he paid the dealer a $500 for a special treatment to bring out the luster in the paint. I told him to ask what the process was.....they clay bar'd then waxed it..... )
Smooth equals even shine on the painted finish.....on glass the same principle applies; smooth is clean. Especially with a new car you can expect all kinds of over spray on your glass - cosmolene for example. Claying your glass removes all that crud with no risk of a scratch. Folks who clay will often save the used clay from doing the paint...and use it to clay their glass. Having the glass baby behind smooth means the wiper blade works better as it doesn't bounce over crud.... Clean glass and a clean blade makes for a good sweep.
I actually run over my windshield with a razor blade a couple of times a year, then clay it....I'm always amazed how much crud I pull up despite twice a week washing
Old Jan 28, 2008 | 04:17 AM
tigergutt1's Avatar
tigergutt1
Isn't this the same kind that BMW uses?
I went to a dealer to get them, but they couldn´t say if the would fit my R56.
What is the modelnumber of the wipers you bought??
Old Jan 28, 2008 | 04:38 AM
Speedwing's Avatar
Speedwing
Don't waste your clay on the outside of your glass!
Use glass cook top polish on your glass. You can purchase it at most appliance stores. It will remove all the water spots and grime and make your glass perfect again. Use Stoners's glass cleaner (Target Auto section) for the inside glass.
