Annoying Armrest
Old Sep 17, 2007 | 03:22 PM
  #26
andyde's Avatar
andyde
I also keep mine out of the way.... my wife uses it the most.
Old Sep 17, 2007 | 04:23 PM
  #27
Robin Casady's Avatar
Robin Casady
My seat is back far enough that folded back is not out of the way.
Old Sep 17, 2007 | 07:36 PM
  #28
Sowellman's Avatar
Sowellman
Originally Posted by Rastven
I was a little concerned about the armrest because I had read negative things about it from day one, even before the R56, but since it's a mandatory component of the bluetooth I was stuck with it.
Since taking delivery I haven't had a single issue with it.
I agree. It isn't nearly as bad as I was led to believe, based upon other people's evaluations. I shift with my hand on top of the shifter and the armrest isn't in the way at all. Maybe others shift down on the shaft.
Mine became more useful today. I received the Razr insert so I can now charge my phone and take advantage of the built-in antenna.
Old Sep 17, 2007 | 07:45 PM
  #29
wondermini's Avatar
wondermini
Since taking delivery I haven't had a single issue with it. It stays locked, never slides open, doesn't get in my way (i'm 6 foot with a fairly normal driving position) and when pushed up it stays there.
I wish I could say the same. Mine comes open at the slightest bump from my elbow. I'm looking to replace it for this reason. It doesn't get in my way at all, it just seems cheap, looks cheap (I hate the plastic silver trim), and won't stay closed.
Seems to me that this is one of those MINI quirks, sometimes you get the version that engineers intended and sometimes you don't.
Probably so if yours stays closed. Or maybe it's just the way I come into contact with mine...I'm sure driver height, habits getting in and out of the vehicle, etc, alter how well the armrest performs (though you could argue this should not be the case.)
Old Mar 23, 2008 | 05:39 PM
  #30
ANT818's Avatar
ANT818
I'll try.
Old Mar 24, 2008 | 01:03 AM
  #31
Oakland Raiders Mini's Avatar
It's safe to say armrest problems are only manual transmission right?
Old Mar 24, 2008 | 04:52 AM
  #32
KrakHor9's Avatar
KrakHor9
Yeah no problems with mine as of yet... it firmly locks into place... a goo place for the sunglasses...
Old Mar 24, 2008 | 09:31 AM
  #33
Robin Casady
Not staying closed, and not folding back far enough could affect all. Getting in the way of shifting would only be a manual trans issue.
Old Mar 24, 2008 | 06:52 PM
  #34
Minidrivr's Avatar
Minidrivr
You guys must have long arms. I'm 5'8" with "normal" arms. The armrest in my Mini is in the exact spot I need it, never opens by itself and doesn't get in the way of shifting or using the parking brake.
Old Mar 25, 2008 | 09:39 AM
  #35
pyskacz's Avatar
pyskacz
Some of us are a touch bigger. That being said, my wife's R56 is an automatic and the armrest is pretty comfortable to use on longer trips, even for me.
Old Mar 25, 2008 | 01:11 PM
  #36
CarolinaCooper's Avatar
CarolinaCooper
Hmmm. I was thinking of ordering an aftermarket one from here:
http://www.armrest-autoaccessories.c...33166718744157
About half the cost. But, some of you have indicated it gets in the way of shifting? This model flips up, and stores more than the OEM model. Any thoughts?
gar56
Nov 15, 2016 06:41 AM
jeri534
Nov 6, 2015 01:40 PM
pglgp1292
Oct 5, 2015 09:34 PM
potterstein
Oct 2, 2015 09:30 AM
Oct 1, 2015 12:13 PM
