Squeal from driver's side window at speed.
Old Jul 31, 2007 | 12:22 PM
Mike Solo's Avatar
Mike Solo
Yes, I've searched.
I have an issue with my 02 MC. The window regulator died on the driver's side, I had it fixed, but now when the window is up and I'm travelling at highway speeds, there is the loudest, most obnoxious squeal I've ever heard coming from the window. It seems as though it's not properly sealing at the top; if I insert two fingers from my left hand between the glass and the A-pillar seal, it goes away, but the second I remove my fingers, it comes back.
Rolling down the window fixes the problem, but I don't always want the window down when I'm on the freeway.
I'd really prefer to fix this myself, if possible. Any idea what the problem might be?
TIA!
-Mike
Old Jul 31, 2007 | 12:49 PM
djam43's Avatar
djam43
Yes your door / window seal is old. BTY, You are in the 07 R56 forum, but if I had that problem with that age of Mini , I would replace the entire seal around the door, as it shrinks with age. It happens to us all, sooner or later.
Old Jul 31, 2007 | 03:09 PM
Mike Solo's Avatar
Mike Solo
My apologies, I didn't even realise I slipped into the 2nd Gen forums. Thanks for your patience with the noobie.
woodstudio
Mar 15, 2020 08:28 AM
polotska
Aug 23, 2015 03:03 PM
cm.d
Aug 19, 2015 08:51 AM
bugeye1031
Aug 15, 2015 08:14 AM
Minibeagle
Aug 13, 2015 10:00 AM
