Removing accelerator pedal?
Old Jun 21, 2007 | 07:49 AM
Dre's Avatar
Dre
How to? I just discovered a couple of days ago that my MC has got a "leak"!!! and that there is some water sitting under the carpet. After taking the entire interior apart I found one of the flex hoses draining water from the sunroof disconected - most likely taken off by either PO or someone else (pissed-off mechanic perhaps??? fixed that but now I'm drying the carpets... would really help if I can remove accelerator pedal to speed-up the process... did anyone do this already?
thanks,
Old Jun 22, 2007 | 03:27 PM
joey1320's Avatar
joey1320
actually the drain tubes on the sunroof pop off all the time. we usually have 1-2 cars a month come in for water leaks. when you put it back try to clamp it down, to keep it in place. oh and do both sides, because even if only one side was off its only a mtter of time before the other pops.
to take off the gas pedal you have to push down on a small tab thats almost in the middle of the pedal. and then pull the pedal towards the drivers door. give it a good pull, then disconnect the plug.
good luck!
Old Jun 22, 2007 | 06:00 PM
moreorless's Avatar
moreorless
good luck!
Hey Joey! You're back!! Congratulations!!
....Les
Old Jun 23, 2007 | 03:08 AM
joey1320's Avatar
joey1320
....Les
thanks. we had fun.
now i'm back to help as mush asi can
maestro39
Oct 27, 2015 02:38 PM
theblackfalcon
Oct 11, 2015 09:49 AM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
greekzilla
Aug 23, 2015 03:44 PM
