SMF (Street Modified FWD) Finished first year novice 1st place
Pretty sure a DSP Mini would easily have the best power to weight in the class if your dyno numbers are accurate, and also the lightest weight. I guess the only question is if one on wide A6s could put it down effectively.
jetsr6 (10-10-2017)
JCW turbo is legal through update / backdate. Tune is legal too. JCW GP stuff is legal too, so GP aero and GP rear seat delete are ok to add to a regular S. I've seen Vitamvas's car, Campbell's car, and the freshly built Hunt car run quite a bit, and they're really fast.
Hmm..... this had me thinking and went back and reread the rules. So the only thing as of now that puts me into SMF is my blow off valve. I can easily put back on my old one with the Alta spring😉. I haven’t done any internal work yet. I did just buy a ported head with race cat cam’s for a great deal. And planed on rising the rpm limits to 8,000 then I could go 72 mph in second with Hoosiers. Hmmm..... Pax would go from .848 to .842
My build would look like this:
Stage 1:
Whatever the hell power package you've got. Car looks crazy powerful.
1.0-way LSD. I hate OS Giken but don't think there's another option. Not sure the Torsen is enough, but it might be. The OE LSD on my car struggles a bit at factory power.
I'd probably start with the 245/40-15 A7 on 9" wheels to keep the car narrow, but definitely test the 275s.
Zero idea what ride frequencies you need in a fwd car on Hoosiers, but I'm guessing there's nothing off the shelf stiff enough. Car would likely be unbearable on the street with what is needed.
Lots of camber.
JCW GP front undertray and a front splitter to the max of the rules. Car will be 100% limited by front grip levels and I'd do anything to maximize it.
I think that's a good, solid, 95% build that would make it quite clear if it's worth going the full monte or if it's a wild goose chase.
With the short wheelbase, light weight, and narrowness of the Mini I think it would wreck the BMWs and RX8s in the little ticky tack transitional stuff. Looks like your car has plenty of power to more than keep up in straight line acceleration. With the fwd penalty the big challenge is sweepers and more importantly getting power down coming out of them. Your car really, really struggles to put anything down but your tires aren't doing you any favors.
Somehow I am going to try to verify the rules over this winter make sure I am good with the JCW turbo for dsp and everything else sounds really good. Obviously I can’t get on the throttle a lot as I’m pulling out of a turn. It will be interesting with the Hoosiers because I’ve really only ran the autocross with two different tires, the federals that are on there now and the Indy 500’s LOL Right now I’m running pretty close to 3° on the front they’re maxed out and on the back I’m running 2.2° camber
MINI
Cooper S (including JCW & JCW GP except Countryman)
I'd say your car is close enough to the rule for everywhere except if you win in Lincoln, as there's zero advantage to an S block over a JCW block.
That's how the line is written, so to be 100% legal to the letter of the law an entire JCW motor including turbo would have to swap in. So I guess your car specifically isn't legal as is, but your power level is legally attainable by someone else copying your setup with an eye on the rules. The whole engine is considered as a power unit so it's good to use via update / backdate, but only the whole thing.
Like I said, SP rules are real bad.
I was under the impression earlier that the S & JCW blocks were identical and I guess they're not after a quick Google search.
Even worse than that, you could start with a base clubman or roadster if you wanted, plop a full JCW GP motor into it on whatever tune you wanted, and be 100% legal. But just swapping the turbo only... isn't legal.
They both used the N14 but the S got the N18 (different block) in like 2011 while the jcw did not get it till like 2013
dont quote me on the year crossovers I dont know the r56 platform that well
