Site Feedback Open forum for discussion of this site. Post your kudos or criticism so that we can continually improve service to the new MINI community.
iTrader Questions & Answers
Old Jun 24, 2008 | 10:03 AM
Mark's Avatar
Mark
North American Motoring :: Founder
Have a question about the new iTrader feature on NAM? Be sure to check out our new Help system for answers. If you still have questions post them here and we'll do our best to answer them.
Thanks!
Mark
Old Jun 24, 2008 | 10:33 AM
El_Griton's Avatar
El_Griton
I just wanted to point out that you can only do 5 ratings in a 24 hour period. I dont think that is said anywhere.
so far I am the MOST trusted person on Nam, according to itrader
Old Jun 24, 2008 | 10:45 AM
wbarnhill's Avatar
wbarnhill
Coordinator :: Upstate MINIs
The only big issues with any feedback system like this are:
1) Retaliatory feedback - A seller leaving negative feedback because the buyer left negative feedback. (Example: Seller sells item which is broken or otherwise unusable. Buyer requests and is denied a return, and now has paid for a broken item. Buyer leaves negative feedback, and seller leaves negative feedback in retaliation.) The other extreme is a buyer demanding something such as free shipping or even the item itself for free or else they will tarnish the reputation of the seller by leaving negative feedback.
It looks like NAM will handle this via admins being notified of negative feedback. What will the process entail for individuals to remedy a retaliatory feedback situation? What burden of proof is on each individual in the transaction?
2) False feedback - A member creates multiple accounts and sells items to himself, generating URLs for feedback. Or multiple members sell small items between themselves (or say they do) in order to build feedback.
The site says that feedback will be limited to 5 per day, but will there be detailed information that could help determine if this method is in use? Would this warrant a notification to an admin, and if so, how?
3) Multiple feedback - A member buys several items from one individual and treats each item as a separate transaction. Or a member buys items separately, but the same thread, and again treats them each as a separate transaction.
Is this acceptable, or are there specific rules for each instance?
Finally, is the iTrader system meant to apply to all users on NAM, including vendors? Is it safe to assume that punishments for running afoul of the system would range from feedback deletion to a ban from NAM?
Sorry for all the questions, but these were just the ones that popped in my head after reading through the Help. Thanks!
Old Jun 24, 2008 | 01:50 PM
gnatster's Avatar
gnatster
Ideally the seller will leave feedback upon payment, that's a best practice and it's noted in the help. Can this be forced, no. If this practice is followed then the buyer will have feedback before the item in hand assuming it was shipping and not a local pickup. These scenarios are quite possible but we do have a mechanism in place to try and prevent this. One only needs to report the issue via the link in the help or the Contact Us link. The help link is to the Contact Us page. It will be reviewed but at this time there are no hard and fast rules. Call it a case by case basis and see how it goes. If it does prove to be a problem the feature can be shut off.
This is not eBay, one should not live or die by the ratings. It is fully expected for the vast majority to have a 100% rating. This tool is more to weed out the few that might be scammer types.
Multiple items from one thread should be treated as a single transaction. Consider the rating to be transaction based and not item based.
Yes this is safe to assume. It is noted in the Help documents that abuse of the system will not be tolerated and members will be subject to bans.
That's OK and even encouraged. It is from this type of discourse that the system can be fine tuned and relevant items added to the Help. I'll be updating the Help with some of this information soon.
Old Jun 24, 2008 | 02:17 PM
gnatster's Avatar
gnatster
It should be noted that the iTrader system is not designed to to rate vendors for transactions that occur outside of the NAM Marketplace. Only if a vendor has an item or items in the Vendor Classified area of the Marketplace should a rating be left. Otherwise please use the Vendor and Product Review area.
Old Jun 24, 2008 | 02:22 PM
gnatster's Avatar
gnatster
It is noted in multiple locations in the NAM Help system.
Old Jun 24, 2008 | 02:31 PM
ngweibing's Avatar
ngweibing
i would like to input my thoughts after using it...
overall i like it but i dun like the part where u have ot find the link of the item in the marketplace thread and put it in... it took me sometime ot find the items i bought... is there a easier way?
Old Jun 24, 2008 | 02:34 PM
gnatster's Avatar
gnatster
Help has been updated.
Old Jun 24, 2008 | 02:42 PM
gnatster's Avatar
gnatster
At this point no.
If you have posted in the thread you can try this.
In the upper right of the screen under the Masthead click on Search
Click on Advanced Search to open the Advanced Search window.
Enter your own User Name in the User Name Field
In the Search in Forums box scroll down the list and either select Marketplace to find all posts or select a subforum that may contain the post
Click on the Search Now button
From the list returned select the proper thread.
Will be adding this to the iTrader Best Practices page in NAM Help
Old Jun 24, 2008 | 03:39 PM
revray's Avatar
revray
Invalid Link Question
I've done three transactions with NAM people in the last 2-3 months. I just posted positive iTrader feedback for two of them, but when I went to post it for the third one, I received a note saying that the thread link was invalid. However, if you check the link out, it is quite obvious that there were a number of deals that have been done from this particular thread (see link below). Is there any way the thread can be corrected and made valid?
https://www.northamericanmotoring.co...d.php?t=137077
_
Old Jun 24, 2008 | 03:48 PM
gnatster's Avatar
gnatster
The link is invalid because it is not in the Marketplace.
Old Jun 24, 2008 | 03:50 PM
revray's Avatar
revray
Can you move to the marketplace? It's obviously a thread that a lot of people used to do transactions. Should I be faulted and not get positive feedback because I bought something off a NAM thread that wasn't posted in the right place to begin with?
Old Jun 24, 2008 | 04:30 PM
gnatster's Avatar
gnatster
PM sent
Old Jun 24, 2008 | 04:52 PM
PGT's Avatar
PGT
how about local forum for sale threads??
also....please up the limit for iTrader submissions for at least the first week or two. I only searched on threads I started in wheels/tires and I didn't get all the way through (I have a TON more to do for others):
vBulletin Message Sorry, but you can not rate any more people today.
Old Jun 25, 2008 | 07:30 AM
eager2own's Avatar
eager2own
I probably missed this but:
I understand ratings going forward should be left as soon as possible, but as to past transactions -- how far back can we go? As far back as we can locate the url?
Edit -- a second question: does a transaction require exchange of cash?
For example, marketplace "seller" offers exhaust free to anyone who'll pick it up . . . is that a transaction? Or what if "buyer" only has to pay for shipping?
Old Jun 25, 2008 | 05:57 PM
HighLife4136's Avatar
HighLife4136
I say either is a transaction. Say you go to pick up the free exhaust 100 miles away and the giver isn't there. Now you have to go back and 'hope' that he/she is there. Same for the shipping thing. If it takes six weeks to ship, it's probably a poor transaction.
Old Jun 25, 2008 | 06:33 PM
gnatster's Avatar
gnatster
Jan 1 08 seems to be a good cutoff, hard to remember details past 6mo or so.
May as well call those transactions as well. But more latitude should be given when stuff is free.
Old Jul 23, 2008 | 05:34 PM
hohod's Avatar
hohod
how about moving the iTrader link?
IMO, the iTrader link is too prominent...and looks dorky. Most users are going to display 0 / 0% forever. Maybe move it to the other side, under the gallery link? The name is dorky too - iTrader? is that like iDrive?
Old Jul 23, 2008 | 05:59 PM
PGT's Avatar
PGT
other sites only display it in the Marketplace forums for just that reason. as for the name, that's not NAM's decision...vBulletin's name for it.
Old Jul 23, 2008 | 06:27 PM
gnatster's Avatar
gnatster
Sorry i didn't see this sooner.
The limit was raised
iTrader looks for a valid URL on the site, so local forums should work fine.
Old Apr 14, 2009 | 10:57 AM
AZblackOUT's Avatar
AZblackOUT
I am having trouble with iTrader, keeps telling me that I have an error in my details. I double and triple check and everything seems alright. Anyone else having the same problem?
Old Oct 18, 2011 | 10:21 PM
cycleorange's Avatar
cycleorange
After checking the rules I have determined that my ad (17" Enkei nt03m wheels) Does not violate any rules yet the posting has been removed, why?
Old Dec 31, 2012 | 01:03 PM
avuton's Avatar
avuton
OP has dead link.
Paul!
Electrical
16
Feb 18, 2025 06:29 AM
Sep 11, 2015 01:15 PM
Sep 3, 2015 10:29 AM
