The Light Bar.....nam Saves $$$$$ Palouber Mini
Old Jan 13, 2007 | 06:06 PM
Carol@PaloUberMini.com's Avatar
THE LIGHT BAR by Palo Uber Mini is still the finest lighting component made in the world.COMPLETELY CONCEALED inside your lower dam and bolts directly to your frame without having to drill steel. The patented bar is comprised of one inch stainless steel then powder coated for years of maintence free enjoyment. THE LIGHT BAR is illustrated in the current issue of New MINI Magazine ( the real Mini Cooper enthusiast publication) and is known world wide. THE LIGHT BAR comes complete with a fully bound and moisture resistant wiring harness with all wires to length and with all connectors already installed. Relays, fuses and quick connects included. The system is ignition activated and the ability to run two or all four lights is built in. You can run our lights without driving or head lamps being on. A powder coated face plate is included along with two illuminated switches. The switches illuminate only when lamps are activated. No tabs to come loose and no leveling of the bar is required. This laser cut device is perfectly constructed and is a Palo Uber trademark item on all Palo Uber Edition Mini S cars. THE LIGHT BAR has been sold world wide for over 3 years and continues to be one of the most imitated products on the market.
NAM members only save $40.00. To order go to www.paloubermini.com then go to store and scroll to find NAM KIT #3 to activate purchase.
Palo Uber Mini products continue to be the finest in the world......
Old Jan 15, 2007 | 07:04 PM
we usually run hellas both here and at the london store, but we have installed several kits with pias, most with upgraded bulbs. yes, no problem with using with our wiring harness and system.....sean
Old Jan 24, 2007 | 08:43 PM
we installed another light bar to the aero kit and we will putting photo guide on our web/faq in the next couple of days...its not hard, but you just remove the grille with the bar already bolted to the frame and then after locating the two center tab holes, put the teplet on and drill your outside two lamp post holes,using the templet, and connect the wires and lamps through the huge grille openining. after the lamps are in , unbolt the bumper/aero from the top bolts, pull it gently forward and snap the grille back in......your done,,yes,,,no drilling steel...for 06 models you use the power from the cigarett lighter and not the purple wire at the stereo....let me know,,,bryce
Old Jan 27, 2007 | 01:44 PM
brian, thanks for the email, yes the bar is stainles steel, laser cut, robotic welded and is powder coated for massive overkill. the bars are made by us at our facility in birmingham england, so we control production and quality that way..call me if you want, no problem...and yes, absolutely, the install on the areo kit is no problem, just let us know when ordering so we can put those specific instructions in with the bar. the only difference is you mount the bar on the car with the areo kit installed, and then work through your grill that you remove while doing the install....looks great !!!
Old Jan 28, 2007 | 02:32 PM
justin, thanks for your email...i currently have three light bars ready to ship that have not yet been sold. so yes, we can ship monday...call me if you want, no problem..bryce smythson :impatient
Old Jan 29, 2007 | 06:09 PM
justin, if you want you can splice all four lamps to come on at one time, but watch out for the men in black. call me if your sure you want to do it and i can talk you through...no problem...bryce :impatient
Old Jan 29, 2007 | 08:21 PM
Mark,
yes we can ship your light bar before frida
Thank you for your order
Old Jan 30, 2007 | 08:27 PM
bill,we got your order ok.....ill go ahead and authorize your shipment tommorow, no problem.try the ax card.
Old Jan 31, 2007 | 08:27 PM
jason, our order cleared customs early and was delivered today... your order has already been packed and went out fed-x at 5:10 pm,pst. so were on our way...many thanks,,sean
Old Feb 11, 2007 | 05:53 PM
we couldn't understand your handles when you left message on the voice mail at the office. if i understood correctly. yes we have installed PIA lamps on several of our palo uber mini's but our wiring harness has connectors already attached and they are to fit the hella lamps. the PIA lamp connectors are much smaller than the hella's , do, a quick run to the supply store abd reconect to the uber harness. don't cut too much back before connecting the smaller leads. call if you need. many thanks, your doing it right, bryce
Old Mar 4, 2007 | 07:08 PM
INVENTORY
I am waiting for my order to arrive from the London Store, but right now i have two in stock ready to ship....bryce
Old Mar 10, 2007 | 04:07 PM
BACK IN STOCK
We just got our shipment in from the London store, so were back in stock. We already shiped the four back-orders from last week today, saturday, and sent them out overnight at no charge....sean
Old Mar 13, 2007 | 08:31 PM
PATENT INFRINGEMENT
DTR; Thanks for the email, we are fuly aware....And the attorney is ready, as we will defend this to the absolute maximum, and they will have to answer to a London Court, which means they will have to retain council there. That A lot of "light Bars" or whatever they are calling them. This is a hands down case, we will probably end up owning that company!!!!!!!! :impatient
Old Mar 28, 2007 | 09:32 PM
Thanks for checking, I do have one left in stock, but my order is due in on friday, so not really a problem either way. If you order tonight, it will ship on thursday. call the office if you want.
bryce
Wohnson89
Jun 10, 2020 04:53 AM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
