R52 Spare Tire in a R52
Spare Tire in a R52
The prior owner replaced the run-flat tires with Cooper CS5 Ultra Touring tires which I think are non-run-flats. This saved me the trouble of replacing the run-flats myself. How are other Cooper S owners who have ditched the run-flats dealing with the combination of the lack of run-flats and the lack of a spare?
My plan is to sacrifice the trunk in exchange for a spare. My questions are:
Does the "micro spare tire and wheel" temporary spare available for MINIs fit in the trunk of the R52 Convertible?
Is the little jack that is in the trunk sufficient for an emergency tire change? Should I upgrade it or put a piece of plywood in the trunk as well?
I appreciate your thoughts.
Thanks for the feedback.
I was OK giving up the trunk space for a spare. Putting the spare in the footwell of the back seat would likely take too much space from the passenger and eliminate room for additional passengers. I also am concerned with the text "This spare is intended to be used on the Rear of your MINI when used. This will prevent transmission damage, and allow you to drive safely. Also this may not clear all front brake calibers, but clears the rear brakes no problem."
Option 2 is to get a used full size wheel / tire and call a friend to make a delivery if I ever need it.
Anybody find any other solution?
https://www.griotsgarage.com/product...fType=&from=fn
This is what I carry and the bag has room for an extra qt of oil, some cleaning supplies for road trips and a fool jug for a short snort at the end of the day.
I've used the supplied jack and it works OK but doesn't provide a great deal of confidence.
miniCPA (01-17-2018)
I don't remember if the spare clears the stock S front brakes. If it doesn't, the usual solution is to transfer the rear wheel to the front and put the spare in the rear. This isn't unusual for upgraded and aftermarket brakes.
With these cars you can lift front or rear side with a good floor jack and change both tires, putting a stand underneath is a good practice as well, never know when that pressure relief valve decides to blow.
I simply carry a can of goo and a tire inflator. Only issue would be a broken valve stem, but then AAA is the backup. In all the years, that has happened exactly 1 time.
Regards,
Jerry
MiniTigger (05-02-2018)
Jerry,
I agree on all counts. A full size spare on the back of a MINI would look much better. It would still not look good but much better.
I have only had a flat tire once my self. Ironically, the thought never crossed my mind to change the tire. I was in a home depot parking lot and bought a pump and filled it. I had to stop on the way home and do it a second time. The problem was not the tire, it was the valve cap that had a nub in it that pushed on the valve.
If I can get a spare in the trunk, I am going with a spare. Otherwise I will get the goo stuff and forget about it.
Another important factor is to not let the tires get too old.
How to tell if your tires are getting too old.
https://www.tirerack.com/tires/tiret....jsp?techid=11
dude the spare fits in trunk
Just so you know i have a mini cooper s R52 2008.The spare tire does fit in the trunk behind the back seat standing straight up.you have to raise the back shelf it has extra position a few inches higher than the stock height(purposely done to fit luggage etc.).The only drawback is that you cannot put the top all the way down,only sunroof style.there is a safety where when you put the shelf up on the higher position it will not allow you to put the top all the way down which is good because the tire is to high and the rear windshield(glass) could break.That's a good solution for the winter but summer just buy a nice cover for spare and put it in the back set.By the way im not talking about a full size spare but the donut everyone has for the mini.
IMO you are not going to get the micro spare in the vert rear trunk. Whereas I had that spare in my R53 being able to stand it up and strap it to the back of the rear seat, the vert shelf is not up high enough. I have a pump, some plugs and a can of green slime.
I carry the spare tire strap in the back seat...
Not being able to put the top down defeats the purpose of the convertible. I decided to go with a can of fix-a-flat, Roadside assistance and a cell phone. Next problem is the fact that the roads that are the most fun in the MINI are the least likely to have cell service. I will figure that one out if I ever get stuck.
This might work but IMO you would have to ratchet type strap to compress the sidewalls and with that type of tire I wonder whether it would deform it thereby causing it to thump bad when inflated/driven.
My kids fit perfectly behind the passenger's seat! Well perfectly is an exaggeration but they wouldn't fit at all if there was a spare in the back. I also question the room in the front passenger's seat if it was pushed up to accommodate a spare tire in the back.
