Interior/Exterior Removal of Side Scuttels
Old 07-17-2011, 07:31 AM
Tacoman03's Avatar
Tacoman03
Tacoman03 is offline
Anyone attempt this yet? I ask as I am looking at wrapping them and needed to know how to remove them safely......any ideas?
Old 07-17-2011, 03:01 PM
less2's Avatar
less2
less2 is offline
Open hood...Then using some kind of prying tool or your hand you have to pull up on the trim piece above the scuttle. Its a little hard to get to come up but it can be done, using the prying tool helps alot. Now remove the light by pressing the white tabs, if you get one out, the lower tab the top will follow. Now disconnect the light and set that to the side. Look down in the compartment you should see several white nylon fastners. These are tricky using your trim tool or what ever you have to pry with, gently pry the top from the outside. You will here some cracking but its the fastners coming loose. Repeat until you have them all out. Theres one at the very bottom along with a long piece of plastic that's attached to the scuttle. To get at that piece and free the scuttle you have to pull back the cars trim a little. After you do that wrap on. Hoped that helped a little. The trim tools I purchased from Harbor Freight, if your going to do alot of work on your car these are a must. It prevents alot of maring
Attached Thumbnails Removal of Side Scuttels-img_2555.jpg   Removal of Side Scuttels-img_2556.jpg   Removal of Side Scuttels-img_2558.jpg
The following 2 users liked this post by less2:
azyre (06-19-2022), OSilvera (10-12-2019)
Old 07-17-2011, 03:26 PM
less2's Avatar
less2
less2 is offline
White fastners from the front view looking into hood.
Last two white fastners and the grey rod attached to the scuttle.
You have to pull back the trim a little to get the scuttle out.
ivegota (04-28-2020)
Old 07-17-2011, 03:45 PM
less2's Avatar
less2
less2 is offline
Hope these help sorry about the iphone pics.
Trim tool is a must.
Attached Thumbnails Removal of Side Scuttels-img_2564.jpg   Removal of Side Scuttels-img_2565.jpg
Old 07-17-2011, 04:08 PM
Tacoman03's Avatar
Tacoman03
These are awesome, if a bit intimidating looking! Thanks a ton, I am actually having the wrap done, and the guy was asking me about removing the scuttle. This will help agreat deal! Thanks again..
Old 07-31-2011, 09:56 AM
Tacoman03's Avatar
Tacoman03
Thanks Less2 as i got them off for my guys to wrap them,,,,good tips and great pics, knew right where to apply pressure...it was a bit scary hearing all the cracking sounds but all is good!
Old 07-31-2011, 10:32 AM
less2's Avatar
less2
less2 is offline
Glad it worked out and the cracking noise is a little alarming. That's why I gave you a heads up. What color you wrapping them in? Please post pics when he's done.
Old 10-12-2011, 08:44 PM
countryman-s's Avatar
countryman-s
countryman-s is offline
THANK YOU less2, helpful members like you are why i'm on this forum.
Old 10-12-2011, 09:42 PM
less2's Avatar
less2
less2 is offline
Glad it worked out....there's nothing more satisfying than doing it yourself.
Rich Rodichok (12-02-2017)
Old 10-13-2011, 09:38 AM
scooterpie555's Avatar
scooterpie555
scooterpie555 is offline
Great pics! Good write up! Thanks!
Old 07-05-2013, 09:17 AM
Ragnar4841's Avatar
Ragnar4841
Ragnar4841 is offline
These instructions worked great! It took just a few mins to get each one off. By the way, a plastic bicycle tire changing tool worked perfectly for prying.
My scuttles are now drying after their first coat of plastidip...
Old 07-30-2013, 06:34 PM
TerminalVelocity's Avatar
TerminalVelocity
TerminalVelocity is offline
Old thread I know but when you say "white fasteners" are you not supposed to remove the blue ones too?
I see 6 blue fasteners that must be squeezed to release plus at least 1 white fastener. I can't for the life of me see how you can get all those to release without them popping back in to place as you work on each one.
EDIT: all it took was for me to write that frustrated post to turn around and figure it out. Lol!
Old 07-30-2013, 07:43 PM
less2's Avatar
less2
less2 is offline
LOL........Glad it worked out.
Old 08-06-2013, 07:12 PM
metroman68's Avatar
metroman68
metroman68 is offline
any updated pics you can post of the final plastidipped scuttles?
Old 08-22-2013, 04:06 PM
etidd01's Avatar
etidd01
etidd01 is offline
Thanks for the write up! Second one was much easier once I realized how much effort I needed to release the panel. One problem I have is that 2 of the clips on my '14 CM slid off the trim panel instead of pulling off the frame, so now I need to find a trim tool to remove and replace them. FML.
Old 10-01-2014, 04:24 AM
R56MINICooper's Avatar
R56MINICooper
R56MINICooper is offline
Sorry to revive an old thread, but I cannot get the bottom pieces out for the life of me, It's stuck behind the trim pretty far it seems and I feel like I am going to break the wheel trim off from the car trying to pry it.
Any suggestions?
Old 10-01-2014, 04:35 AM
ASKtheteach's Avatar
ASKtheteach
ASKtheteach is offline
There is a plastic pin that holds them in place at the bottom in place. You'll need to grntly pry away the black trim.
Old 10-01-2014, 04:38 AM
R56MINICooper
I tired pulling the trim back but they seems fairly anchored in by two more of the connectors like the white ones in the pictures here. I'm afraid to break any fasteners that hold the wheel well trim on :(
Old 10-05-2014, 07:46 AM
Vegasbaby's Avatar
Vegasbaby
Vegasbaby is offline
This did it for me. Got in there and it popped right off after days of worrying what to do.
http://m.harborfreight.com/5-piece-a...not%20provided
Old 12-02-2017, 11:55 AM
Rich Rodichok's Avatar
Rich Rodichok
Rich Rodichok is offline
Before
After
Great write up!!! Made it so easy. I know most people tend to black out their MINIs. I like a little additional (plastic, yes) chrome. Next is brake ducts. Just don’t know yet if I want the ones with the LED DRLs or without.
Old 12-30-2017, 08:58 AM
minimontes's Avatar
minimontes
minimontes is offline
great write up on removal- Im actually planning on some color work as well on my scuttles. this helps a lot
Old 12-30-2017, 03:30 PM
Going to move this to the Mod area. Trying to do a little cleaning up here in the Countryman subforum until somebody volunteers to help out.
Old 01-02-2018, 06:36 AM
minimontes's Avatar
minimontes
this helped get the first parts going; I went super lazy and instead of putting stress on plastic parts I just took a razor knife to the clips- At $0.67 from outmotoring I figured who cares. Ive had the clip holders on the part brake way too many times, or once getting it back in after struggling and the clip going in and out of the mount hole a dozen times (which is what was happening yesterday) the part ends up rattling because the clip lost its rgidity.
so, plasti-dipping the parts today,
thanks for showing the steps, its super easy to do
Old 07-15-2019, 09:50 PM
Jeremy A Gruver's Avatar
Jeremy A Gruver
Jeremy A Gruver is offline
Thanks! Worked for me!
Hey guys thank you for this thread! I see very few side scuttles done for some reason. Doing mine as well! Going for red on my countryman. Wanted to try wrap but man is it a pain haha 😅
Old 04-20-2020, 11:26 PM
ItzNeil's Avatar
ItzNeil
ItzNeil is offline
I recently removed mine and sprayed them in Anthracite plastidip. TO remove the clips easily, use a 1/4" breaker bar with an 8MM socket. Place the socket over the pointy end of the clip and press gently. The socket will squeeze the tab on the clip so it pops out very easily. Start at the top. you can then use a 6MM to free the two clips you can reach holding on the fender flare. Finally, once I removed the first scuttle, I trimmed the 1" long locating pin under the fender to 1/2" so that I needed far less movement in the fender flare to refit the scuttle. For the second one, I used a loose hacksaw blade that I bent slightly to again trim the pin length to about 1/2" BEFORE I removed it to make removal and replacement much easier on the fender flare.
The following 2 users liked this post by ItzNeil:
bugeye1031 (02-18-2024), ivegota (04-27-2020)
Quick Reply: Interior/Exterior Removal of Side Scuttels
