R50/53 Oddments tray 51160395790
Old 06-19-2015, 10:11 AM
AoxoMoxoA's Avatar
AoxoMoxoA
AoxoMoxoA is offline
I know this part (circled and illustrated in red) is marked "no longer available" on many vendor's sites, but I was wondering if anyone out there in MINI-land had one of these that they are willing to part with, i.e., sell to me for inclusion into my '04 R53 ?
Old 06-19-2015, 10:19 AM
PelicanParts.com's Avatar
PelicanParts.com
PelicanParts.com is online now
51160395790 is showing in stock for me on our website, ships in about 5 business days. Checked the data base too and it doesn't say it's NLA (always an exception though). Can try it out.
-Luccia
Old 06-19-2015, 10:39 AM
Received 2,000 Likes on 1,796 Posts
Its NLA and been for a while now for most distributors. MINI does not have them either since about before 2012.
51160395790
http://www.ecstuning.com/Search/SiteSearch/51160395790/
Good luck I can hope you can find one used.
Otherwise you can upgrade the center console to the newer style with the front tray.
51166958571
http://www.ecstuning.com/Search/SiteSearch/51166958571/
51167131830
http://www.ecstuning.com/Search/SiteSearch/51167131830/
Rubber Insert - Rear Cup Holder 51167131183
http://www.ecstuning.com/Search/SiteSearch/51167131183/
51166950147
http://www.ecstuning.com/Search/SiteSearch/51166950147/
and the rear cup ring in silver, you can get
Silver Drink Ring Holder - Rear
http://www.ecstuning.com/Search/SiteSearch/51167132798/
This is of course the set up without the factory armrest.
If you need anything else let me know.
Old 07-18-2016, 08:00 PM
swunder's Avatar
swunder
swunder is offline
51160395790
51166958571
51167131830
51166950147
Hey, I just had my order for the oddments tray cancelled by pelican (not in stock of course).
I have a pre facelift 04, are these all the parts I need for the upgrade? Would my existing leather boot attach to the new center console handbrake holder (or can I use the existing handbrake holder)?
I'd also probably pair it with the front tray under the toggle switches, no problem there right?
https://www.ecstuning.com/Search/Sit...798/ES2804328/
Thanks!
Old 07-19-2016, 12:19 PM
Yep, its converting from a pre 2004 to a 2005+ Swap everything over to the 2005 look
Same with the storage.
Old 07-19-2016, 03:53 PM
sevin's Avatar
sevin
sevin is offline
Does the parking brake boot still fit? Do we need a different bracket for it? My MINI is 08/2003.
Old 07-20-2016, 08:43 AM
sevin's Avatar
sevin
sevin is offline
Okay, according to the website, the newer style center console can be retrofitted, but it needs a different support bracket. Is 51167131830 the one?
Old 07-21-2016, 06:24 PM
Black-eyed-Purple-Mini S's Avatar
Black-eyed-Purple-Mini S is offline
R53 rubber pieces
Are these the pieces you are looking for I have a set out of my R53?
Old 07-21-2016, 07:31 PM
X757XVeritas's Avatar
X757XVeritas
X757XVeritas is offline
I'm guessing he's talking about this rubber tray.
It's for the original design Center console. Just sits on top of the carpet between the gap from console to shifter.
I didn't realize how hard they were to find till people started asking me where I got it. Came with the car always surprises everyone.
Old 07-22-2016, 06:45 AM
Its the same boot.
On the mounting base , yes
https://www.northamericanmotoring.co...p-armrest.html
Old 07-22-2016, 06:49 AM
Yes, those are NLA and hard to find. Old School MINI stuff
Old 07-22-2016, 08:37 AM
sevin's Avatar
sevin
sevin is offline
Its the same boot.
So the mounting base and everything will fit a pre-facelift? Just need the bracket and I'm good?
Old 07-22-2016, 08:38 AM
Yes, you need the 2005+ parts and replace your pre 2005 parts.
Old 07-22-2016, 01:36 PM
Eric_Rowland's Avatar
Eric_Rowland
Eric_Rowland is offline
I did the conversion a while ago. Didn't see the need to change the bracket. IIRC there was one screw that wasn't needed, but it's been solid for years.
I've got the oddments tray set (front of console and front of shifter) PM me if interested.
Old 07-22-2016, 02:13 PM
sevin's Avatar
sevin
sevin is offline
Does the new design block the TPMS reset switch? That's the only problem I'm still seeing.
Old 07-23-2016, 03:59 AM
X757XVeritas
The old design covers the switch, but if you have to use that button enough for it to be that much of a hassle to move a tray you have some other issues to resolve.
Old 07-23-2016, 11:20 AM
MINIAC's Avatar
MINIAC
MINIAC is offline
Contact Eric and go Old School!
You can easily move the rear tray if you have to reset the TPMS.
Old 07-23-2016, 11:54 AM
sevin's Avatar
sevin
sevin is offline
Wait, you're both confusing me. I'm not interested in the trays, I'm talking about upgrading the entire console tunnel to the new design that integrates the tray. It doesn't have a hole for the central TPMS reset switch, it has 2 on the outside.
Old 07-23-2016, 12:09 PM
X757XVeritas
Oh, this thread started talking about the trays for the original design, I didn't realize the OP had disappeared and we changed directions. My bad!
Old 07-23-2016, 01:39 PM
MINIAC's Avatar
MINIAC
MINIAC is offline
I would imagine it's just a matter of relocating the switch.
Old 07-23-2016, 03:22 PM
sevin's Avatar
sevin
sevin is offline
What are the two side holes even for?
Old 07-23-2016, 05:31 PM
MINIAC's Avatar
MINIAC
MINIAC is offline
RealOEM lists part 7 as Cover, switch PDC
Old 07-23-2016, 05:33 PM
sevin's Avatar
sevin
sevin is offline
So one is for TPMS and the other is for PDC? That has a switch?
MORENOJM
09-20-2016 08:13 PM
minimofo
11-05-2015 08:40 AM
sempaipaul
09-12-2015 01:04 PM
Accessory Products
09-09-2015 10:29 AM
AdrenaliNate
08-24-2015 12:37 PM
Quick Reply: R50/53 Oddments tray 51160395790
