R50/53 Oddments tray 51160395790
Old Jun 19, 2015 | 10:11 AM
AoxoMoxoA's Avatar
AoxoMoxoA
I know this part (circled and illustrated in red) is marked "no longer available" on many vendor's sites, but I was wondering if anyone out there in MINI-land had one of these that they are willing to part with, i.e., sell to me for inclusion into my '04 R53 ?
Old Jun 19, 2015 | 10:19 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
51160395790 is showing in stock for me on our website, ships in about 5 business days. Checked the data base too and it doesn't say it's NLA (always an exception though). Can try it out.
-Luccia
888.280.7799 | 6am - 5pm PST
Old Jun 19, 2015 | 10:39 AM
Its NLA and been for a while now for most distributors. MINI does not have them either since about before 2012.
51160395790
http://www.ecstuning.com/Search/SiteSearch/51160395790/
Good luck I can hope you can find one used.
Otherwise you can upgrade the center console to the newer style with the front tray.
51166958571
http://www.ecstuning.com/Search/SiteSearch/51166958571/
51167131830
http://www.ecstuning.com/Search/SiteSearch/51167131830/
Rubber Insert - Rear Cup Holder 51167131183
http://www.ecstuning.com/Search/SiteSearch/51167131183/
51166950147
http://www.ecstuning.com/Search/SiteSearch/51166950147/
and the rear cup ring in silver, you can get
Silver Drink Ring Holder - Rear
http://www.ecstuning.com/Search/SiteSearch/51167132798/
This is of course the set up without the factory armrest.
If you need anything else let me know.
Old Jul 18, 2016 | 08:00 PM
swunder's Avatar
swunder
51160395790
51166958571
51167131830
51166950147
Hey, I just had my order for the oddments tray cancelled by pelican (not in stock of course).
I have a pre facelift 04, are these all the parts I need for the upgrade? Would my existing leather boot attach to the new center console handbrake holder (or can I use the existing handbrake holder)?
I'd also probably pair it with the front tray under the toggle switches, no problem there right?
https://www.ecstuning.com/Search/Sit...798/ES2804328/
Thanks!
Old Jul 19, 2016 | 12:19 PM
Yep, its converting from a pre 2004 to a 2005+ Swap everything over to the 2005 look
Same with the storage.
Old Jul 19, 2016 | 03:53 PM
sevin's Avatar
sevin
Does the parking brake boot still fit? Do we need a different bracket for it? My MINI is 08/2003.
Old Jul 20, 2016 | 08:43 AM
sevin's Avatar
sevin
Okay, according to the website, the newer style center console can be retrofitted, but it needs a different support bracket. Is 51167131830 the one?
Old Jul 21, 2016 | 06:24 PM
Black-eyed-Purple-Mini S's Avatar
R53 rubber pieces
Are these the pieces you are looking for I have a set out of my R53?
Old Jul 21, 2016 | 07:31 PM
X757XVeritas's Avatar
X757XVeritas
I'm guessing he's talking about this rubber tray.
It's for the original design Center console. Just sits on top of the carpet between the gap from console to shifter.
I didn't realize how hard they were to find till people started asking me where I got it. Came with the car always surprises everyone.
Old Jul 22, 2016 | 06:45 AM
Its the same boot.
On the mounting base , yes
https://www.northamericanmotoring.co...p-armrest.html
Old Jul 22, 2016 | 06:49 AM
Yes, those are NLA and hard to find. Old School MINI stuff
Old Jul 22, 2016 | 08:37 AM
sevin's Avatar
sevin
Its the same boot.
So the mounting base and everything will fit a pre-facelift? Just need the bracket and I'm good?
Old Jul 22, 2016 | 08:38 AM
Yes, you need the 2005+ parts and replace your pre 2005 parts.
Old Jul 22, 2016 | 01:36 PM
Eric_Rowland's Avatar
Eric_Rowland
I did the conversion a while ago. Didn't see the need to change the bracket. IIRC there was one screw that wasn't needed, but it's been solid for years.
I've got the oddments tray set (front of console and front of shifter) PM me if interested.
Old Jul 22, 2016 | 02:13 PM
sevin's Avatar
sevin
Does the new design block the TPMS reset switch? That's the only problem I'm still seeing.
Old Jul 23, 2016 | 03:59 AM
X757XVeritas
The old design covers the switch, but if you have to use that button enough for it to be that much of a hassle to move a tray you have some other issues to resolve.
Old Jul 23, 2016 | 11:20 AM
MINIAC's Avatar
MINIAC
Contact Eric and go Old School!
You can easily move the rear tray if you have to reset the TPMS.
Old Jul 23, 2016 | 11:54 AM
sevin's Avatar
sevin
Wait, you're both confusing me. I'm not interested in the trays, I'm talking about upgrading the entire console tunnel to the new design that integrates the tray. It doesn't have a hole for the central TPMS reset switch, it has 2 on the outside.
Old Jul 23, 2016 | 12:09 PM
X757XVeritas
Oh, this thread started talking about the trays for the original design, I didn't realize the OP had disappeared and we changed directions. My bad!
Old Jul 23, 2016 | 01:39 PM
MINIAC's Avatar
MINIAC
I would imagine it's just a matter of relocating the switch.
Old Jul 23, 2016 | 03:22 PM
sevin's Avatar
sevin
What are the two side holes even for?
Old Jul 23, 2016 | 05:31 PM
MINIAC's Avatar
MINIAC
RealOEM lists part 7 as Cover, switch PDC
Old Jul 23, 2016 | 05:33 PM
sevin's Avatar
sevin
So one is for TPMS and the other is for PDC? That has a switch?
MORENOJM
Sep 20, 2016 08:13 PM
minimofo
Nov 5, 2015 08:40 AM
sempaipaul
Sep 12, 2015 01:04 PM
Accessory Products
Sep 9, 2015 10:29 AM
AdrenaliNate
Aug 24, 2015 12:37 PM
