Suspension Springs, struts, coilovers, sway-bars, camber plates, and all other modifications to suspension components for Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs.
Suspension R58 Strut Tower Brace
Old Mar 7, 2016 | 05:57 AM
flyjets01's Avatar
flyjets01
Hi
I have read one comment on here about how it tightens up Steering response.
My question has it made the ride rougher?
This is my little play car for errands I am not looking for a harsher ride just a few mods to improve steering feel.
Any input would help Thanks in advance.
Ian
Old Mar 11, 2016 | 08:09 AM
https://www.northamericanmotoring.co...os-only-9.html
Looks like this what you were looking for, but it adds rigidity a bit, Are you on factory run flats ? Those can make the ride harsh, switch to non runflats and it a big difference. Also a front and rear sway bar will also help the control.
Old Mar 11, 2016 | 06:39 PM
flyjets01's Avatar
flyjets01
ECS Tuning
It appears I am running the
CONTISPORTCONTACT 3 SSR
They ride harsh handle OK the grip is good I don't see the R58 breaking traction like my wife's Cayman S did with them.
I am a fan of the Michlen Pilot Sport Tires
Ian
Old Mar 14, 2016 | 10:53 AM
I had those on my original R58 JCW R112 wheels , they did not last long and got loud after a while, that's a stock tire MINI used for a while in the runflat, Its i little hard, and little more money, get ride of the runflats and you Will notice a big difference, get the STB for bit more front end rigidity.
Old Mar 14, 2016 | 07:35 PM
flyjets01's Avatar
flyjets01
Thanks ECST
Old Mar 16, 2016 | 08:04 PM
WayMotorWorks's Avatar
WayMotorWorks
The strut brace will make little to no difference as the frame rails are so short that it doesn't need stiffening.
If you want to improve the handling the rear sway bar like an Hsport comp rear bar will do the most for handling. Also a good set of non runflat tires and good alignment
Old Mar 16, 2016 | 08:51 PM
flyjets01's Avatar
flyjets01
WayMotorWorks
Thanks for taking the time to answer.
Ian
Old Apr 8, 2016 | 08:34 PM
flyjets01's Avatar
flyjets01
Strut Brace Update
Picked up the JCW front Strut Brace today, Installed it in about 10 min no issues on R58 Coupe JCW.
There is a Brake vent that is touching the strut brace but it's double insulted and I added some rubber insulating tape to protect it.
Handling is actually slightly different turn in is more direct and chassis is a bit firmer.
Ian
Old Apr 11, 2016 | 11:12 AM
Thanks for the update looks great in the bay. And the feedback. I like mine.
GAT
Mar 11, 2016 04:36 AM
glhboy
R55 :: Clubman Talk (2008+)
Mar 8, 2016 11:51 AM
Khai
Mar 5, 2016 03:33 PM
BroBeanz
Mar 3, 2016 10:06 AM
Rock944t
Feb 29, 2016 09:22 PM
