D Stock Video from 2006 Solo Nationals
It worked for me, although, "OK" was not highlighted when attempting to open. I clicked "OK" anyway, and it worked. Not sure if that was the issue for any of you or not, but it worked for me.
This is what I get...
C00D1197: Cannot play the file
Windows Media Player cannot play the file. You might encounter this error message for one of the following reasons:
- Your computer is not connected to the local area network (LAN) or to the Internet. Connect to the network or Internet, and then try again.
- The path to the file is not valid. If you typed a Uniform Resource Locator (URL) in the Open URL dialog box, verify that the file name is spelled correctly and that the path to the file is correct, and then try again. If you clicked a link on a Web page, the link might not be valid.
- The server is not available (for example, the server is busy or not online). Try again later.
- Some network protocols in the Player are not enabled. Enable all network protocols, and then try again.
- The proxy server settings for the Player are not configured properly. Verify that your proxy settings are correct, and then try again.
I'm guessing it has something to do with the convoluted file name I used.
Try this:
http://gwl.rmsolo.org/misc/CraigHPT2006.wmv
Please let me know if it works.
GRaeme
Try this:
GRaeme
hsautocrosser
SCCA Solo and ProSolo
Sep 15, 2015 09:35 PM
