Solo Jack Stands
Old Sep 16, 2006 | 08:58 AM
Gromit801's Avatar
Gromit801
Jack Stands
Mitchman brought this up in another forum, but I figured I'd ask here since a lot of guy swap all four tires at events.
Where's the best place to put the jack stands under a Mini to have all four wheels off the ground?
Old Sep 16, 2006 | 02:31 PM
JustGo4It_'s Avatar
JustGo4It_
Do one side at a time, then you don't need the stands. Getting all corners up on stands can be tricky, I have done it in the garage. I normally set them on the jacking points.
Old Sep 16, 2006 | 03:36 PM
justintime's Avatar
justintime
the jacking points work best. however it would be a waste of time to do that. like james said one side at a time is best
Old Sep 16, 2006 | 07:10 PM
Mineon's Avatar
Mineon
In six years of autocrossing, I've never needed to get all four corners off the ground on the site at one time. I don't even bother with jackstands, because I don't get under the car when changing tires, and I always jack on level ground.
-Keith
Old Sep 16, 2006 | 07:21 PM
nygaard's Avatar
nygaard
Ok, I don't think that the question has been answered.
I have had the car on four jack stands a couple of times. Each time, I took a two by four about 1-2 feet long, lined it up with the "frame rail" that runs just inside of the jacking pucks, and that is where I jacked it (the two by four spreads the load along the "rail"). I made sure was far enough back to allow jack stands to fit once it was jacked up. I put the jack stands under the jacking pucks. Then I just went to the other side and did the same thing. I must say that I was always concerned about the side that was on jack stands while I was jacking the other side up, worried that a jacking puck would break off, but fortunately it never happened. I also had a jack on both sides as a back-up in case something happened.
Jake
Old Sep 17, 2006 | 05:13 PM
mitchman's Avatar
mitchman
Thanks Jake. Funny that you answered my question. I should have just emailed you!
Good luck next week! (I'll be thinking of you guys while I'm driving the new car)
Filmy
15
Jun 6, 2023 06:27 AM
Doc Pain
Mar 10, 2021 04:50 AM
OutMotoring
Mar 3, 2017 06:29 AM
martinb
Oct 7, 2015 05:00 PM
