D Stock R56 Crash Bolts?
Old Dec 30, 2009 | 03:40 PM
koitus's Avatar
koitus
R56 Crash Bolts?
Does anyone know if Mini has factory approved a set of crash bolts that allows us to increase negative camber in front?
Old Dec 30, 2009 | 04:36 PM
glnr13's Avatar
glnr13
the strut top bolts are not removable so crash bolts won't work.
see part #1:
http://www.realoem.com/bmw/showparts...77&hg=31&fg=10
I have seen some r56'rs remove a plastic lock pin that probably gives a half a degree at best but i think your best bet to gain camber is to get camber plates.
Old Dec 30, 2009 | 06:32 PM
koitus's Avatar
koitus
Thanks for the info. Figured it was worth a try. I just gt my car, and am running it in (as of this upcoming Fri.) D Stock, so camber plates are unfortunately not in the cards, unless I decide to build out the car more and run in in one of the more built out classes.
Old Dec 30, 2009 | 06:59 PM
glnr13's Avatar
glnr13
stock class is the best place for MINI's. good luck
Old Feb 2, 2010 | 06:53 PM
dentspeed's Avatar
dentspeed
The way the strut mounts at the lower part won't allow any movement to gain camber anyway. It's not the normal two bolt mount like a regular strut as with subaru or toyota. Just pull the plastic pin like he said and slide the top. You don't get much. I got about a quarter of a degree.
fireofficer001
Sep 1, 2015 09:49 AM
minibenworks
Aug 30, 2015 08:45 PM
minipopkart
Aug 13, 2015 05:22 AM
minipopkart
Aug 9, 2015 12:13 PM
