D Stock V710 failure
Old Jul 30, 2007 | 06:46 PM
  #26
OasisT's Avatar
OasisT
Originally Posted by ScottinBend
That has always been my settings---42f/36r. Isn't setting the rears that high just covering a mishandling car? I am not trying to start a war here, just never heard of running that high a pressure. I know you can play with the rear pressures to help with under/oversteer but have never seen pressures that high before.
This has been my experience, not sure if I have been doing things right or not, but this has been my experience......
It definitely helps with rotation having the higher pressures. Lower pressures also allow for rotation, just a different kind. High pressure rotation is more of a quick and precise rotation. Low pressure rotation is a slower, more predictable rotation. I, myself, like the quicker/more precise rotation. Sort of a quick off throttle, rotate, back on throttle respose with very little off throttle time in order to induce rotation. If the R53 had 2.5 negative camber up front to optimize front grip, it wouldn't probably benefit from higher pressures with a 215/40/16 V710 on the rear to take away grip from the rear. The first and foremost goal is to optimize front grip, but, with no camber, there isn't much besides shock settings and front pressure that can be changed. Basically, setup front fairly soft, put pressures 45ish and adjust rear accordingly to induce desired rotation. Thats about all that can be done. :-)
Old Jul 30, 2007 | 07:39 PM
  #27
ScottinBend's Avatar
ScottinBend
Got it. Just have never heard of this before.
Thanks OasisT
Old Jul 31, 2007 | 01:19 PM
  #28
MattMan's Avatar
MattMan
Coordinator :: Minis Under the Arches (Oct 25-28)
yeah, most of this is just your personal prefrence of rotation. I personally run mine even lower than most all that have been mentioned. I run around 39f/34r (this varies on surface type and surface temp). I've played with air pressure like nobody's business over the last 2 seasons, and this is what's given me the best results for my V710's.
Old Jul 31, 2007 | 01:22 PM
  #29
OasisT's Avatar
OasisT
Of course surface type/temp/wet/dry will change everything too.
Old Aug 2, 2007 | 07:37 AM
  #30
41 h stock's Avatar
41 h stock
Pressures in stock trim are quite different than from a modded set-up. For example, here are some pressures I have run on the exact same set of tires before and after modifications.
Stock Class: Front 48-50psi (fighting tire roll-over) Rear 50+psi (for rotation).
FSP Class: Front 42psi (-2.1 degrees camber) Rear 35psi
(see signiture below for complete list of mods)
Old Aug 2, 2007 | 10:20 AM
  #31
markertoo's Avatar
markertoo
Early on when I was competing, I always used lower pressures in the rear to induce rotation. I eventually thought about it and figured that since there is an optimum pressure for grip and anything above or below that pressure would reduce the pressure, I would use higher pressures, since the tire would have less friction, and that should be faster.
Someone mentioned earlier that this was to mask a poor handling car. Um, what do we think STOCK cars are?
But, I have to admit, I have to run slightly lower pressures in the front. If I run anything higher than 40-42psi, there is less ultimate grip. I have found the optimum to be in the 38-40psi range, even though it looks like the tire is rolling over too much. Running the larger tires has helped this.
Old Sep 7, 2007 | 07:39 AM
  #32
rataha's Avatar
rataha
I am hoping it was just a defective tire doesn't seam to be any other good explanation guess time will tell
Old Sep 9, 2007 | 03:01 PM
  #33
mitchman's Avatar
mitchman
Originally Posted by rataha
I had an incident with a V710 during an AutoX this weekend, was curious if anyone else had experienced the same? late on the course I was very deep in a turn front passenger tire rolled off the rim 50lbs of air high 80's Don't appear to have any damage rims were MINI 16" 5 spoke R84s I think. No apparent tire damage I will try and get it re seated this week. Its possible the tire was slipping on the rim before hand I was told it looked funny the intire run. To bad I think I would have knocked off an excellent run felt like I was really moving.
any comments would be appreciated.
On the bright side I can now honestly say I have driven the tires off the car
1. Were the tires recently mounted? Like the same day of the event? If so, the slippery stuff they use to mount the tires may not have dried yet.
2. Also, the stock rims have a "run flat shelf" that makes stiff sidewall race tires much more difficult to mount than with standard rims.
Maybe both 1 & 2 contributed to the failure?
Old Sep 10, 2007 | 08:10 AM
  #34
rataha's Avatar
rataha
It was the 3rd event for the tires as I recall
Old Dec 7, 2007 | 05:10 PM
  #35
C2Ron's Avatar
C2Ron
tire/wheel detachment
Late to the party, but just have to contribute my two cents.
I would bet money on a mounting error. 710s are an absolute ***** to mount, particularly if you get down into the 40 series. Lots of lube, lots of heat, and sometimes they still don't want to seat properly.
Its the tire pressure that keeps the bead properly seated, so its a low pressure that would cause this failure if the tire was correctly mounted.
genik
Oct 4, 2016 08:36 AM
Engender
Sep 23, 2015 03:38 PM
Sep 22, 2015 02:05 PM
Rainforest_Elf
Sep 15, 2015 12:11 PM
hong
Sep 13, 2015 06:41 PM
