Quick disconnect Steering Wheel
After doing a bit of research I found out that the mini uses a dual stage inflator module. So the plug behind the steering wheel should be good with a 3.3ohm resistor to prevent the airbag light to come on. However , there is a black plug as well which is used for a slower and minor crash situation. It activates the airbag by a fewer milliseconds to cause less injurys at low speeds.
It would be great if I had a tool where I could measure how much electricity is going threw the black plug so I would know which resistor I should put into that one. I will try to get a tool or just use 3.3ohms for both plugs and see if that works and report back to you folks.
Thanks alot for the info you guys have provided me. Especially you gnatster.
you know what's even easier? black electrical tape covering up the airbag light like everyone else does who doesn't want to hack up the system.... i did that 4 years ago when i pulled the factory seats and before then on my last car for CELs that wouldn't go off due to mods, its safer and can be reverted easier than "tricking the system".....
just a thought!
just a thought!
trw92a
Aug 26, 2015 01:47 PM
Navigation & Audio Steering wheel controls for music
MES11
Navigation and Audio
Aug 6, 2015 08:52 AM
nismo4life
Aug 5, 2015 08:31 AM
