Road Racing Discussion Interested in taking your MINI road racing? Find out what you need to do to get your MINI ready!
Team Onasled and M7
Old Sep 5, 2007 | 01:18 PM
  #576
TheBlackBrian's Avatar
TheBlackBrian
Originally Posted by onasled
Thanks,
So, I was wondering if you decided to take the Kart route? You mentioned that maybe you would dump the Mini and take up karts. All I can say is. go for it! After doing this stuff with my son I would love to take it up myself, and problably will. Never too old !
Just checkin up on ya man. Are you out'a the Mini?
The MINI is going to go up for sale after SEMA. CravenSpeed wants to show off some products... So if anyone is interested, let me know .
I still am going to look into karting as a motorsport release. I can't stop once I have started. Too damn addictive. Its unfortunate that the kind of auto racing I would like to do seems so far out of my league (dollar wise) right now.
-Brian
Old Sep 8, 2007 | 04:41 PM
  #577
onasled's Avatar
onasled
Little bit of a setback today. Would have been first road test but had some clutch issues. Oh well, .... ... good practice on just waht it takes to remove the motor/drivetrain now. Looks like with some practice it takes about 40 min by myself. I'd say 20 with two.
Hope to have it out to test tomorrow, but still not sure what is causing the problems.
Old Sep 8, 2007 | 05:09 PM
  #578
Rally@StanceDesign's Avatar
Rally@StanceDesign
I want those rear arches
Old Sep 8, 2007 | 05:11 PM
  #579
Rsstopper's Avatar
Rsstopper
Coordinator :: RSR Motorsports Forum
Is the clutch dragging? If so, I can shed some light on the problem.. Send me a PM.
Randy
Old Sep 8, 2007 | 05:47 PM
  #580
onasled's Avatar
onasled
Randy
Randy, Slave won't depress pressure plate to release clutch plate. Thought I might have put the clutch plate in backwards, which I see I may have done, but after looking at it, I don't see how that would have effected this. Could the factory slave not be sufficient?
Old Sep 9, 2007 | 01:11 PM
  #581
onasled's Avatar
onasled
x
Old Sep 9, 2007 | 03:26 PM
  #582
Rsstopper's Avatar
Rsstopper
Friggin A! Still does not disengage.
To me this looks like enough travel, but apparently not... ??
Will upgrade to a 3/4" bore master rather then the 5/8" that I'm using now.
Video
http://video.google.com/videoplay?do...78667756653013
We couldn't find a replacement slave in the aftermarket that fit . . . I sent you a PM.
Randy
Old Sep 9, 2007 | 03:52 PM
  #583
onasled's Avatar
onasled
x
Old Sep 9, 2007 | 05:09 PM
  #584
RED FURY's Avatar
RED FURY
SURE LOOKS PRETTY !!!
Old Sep 9, 2007 | 05:24 PM
  #585
TheBlackBrian
Thats quite the exhaust clip...
Old Sep 9, 2007 | 06:20 PM
  #586
k-huevo's Avatar
k-huevo
Help me get a better understanding about the clutch travel problem with some more details please. The slave plunger can only move so far before the clutch release arm is at the end of its arc, at that point the slave piston shaft will no longer have leverage and that’s a good thing because the release bearing would come off the release fork’s tines if the release shaft rotated over 70 degrees. It would seem that an overmatch of master volume would help effort but as long as it is at least equal then travel should be the same. Have you measured the depth of the clutch and flywheel combo at the pressure plate release fingers to be sure it is not too shallow?
Old Sep 9, 2007 | 08:01 PM
  #587
Rsstopper's Avatar
Rsstopper
Thanks Randy.
My advantage "might" be that I am using aftermarket pedals and masters. In thinking about it I do think that moving to a larger master might do it. Think I'll even go 1".
I'm using a Quartermaster clutch/flywheel. I'll call them tomorrow
Greg:
In theory, the volume of the master cylinder should make no difference. Neither should the type or brand of pedals used. If the slave cylinder needs 2 oz of fluid to fully deploy (example only, I have no idea how much), then it should make no difference how big the master cylinder is. In fact, too much fluid could cause a hard pedal if there is no place for the fluid to go . . .or, it could blow out the seal on the slave. (blown seals ARE a problem on the slaves. We carry 4 spare slaves!).
Before you go to more trouble and expense, check ALL the measurements of the new clutch AND the flywheel. Your problem sounds like something is mismatched. You know my story . . . remember it took two transmissions for me before I figured out what was wrong!
If you still have your stock flywheel and clutch . . . mate them up and compare.
Randy
Old Sep 9, 2007 | 08:33 PM
  #588
kapps's Avatar
kapps
Forgive me if I'm incorrect about the master/slave arrangement but wouldn't a larger master cylinder flow more fluid, thus causing a heavier pedal (less hydraulic advantage) as well as need less pedal travel to fully compress the slave? Moreover, as long as the travel is the same between the OEM clutch/flywheel setup and the new one (and within the adjustment range of the slave), there should be no difference in pedal travel.
Onasled, when you made your own pedal box, did you keep the pedal ratio's from the stock setup or change them? Is there a possibility that you're not getting as much pedal travel as you need? In this case, a larger master cylinder might do the trick as long as you don't go too big and blow the slave like Randy mentioned.
Old Sep 9, 2007 | 08:53 PM
  #589
Rsstopper's Avatar
Rsstopper
Good points . . . Greg's video shows the slave travel and it looks like it's at its limits (Onasled needs to verify). If so, the problem would seem to be at the pressure plate / clutch.
Randy
Old Sep 10, 2007 | 03:22 AM
  #590
onasled's Avatar
onasled
x
Old Sep 10, 2007 | 10:23 AM
  #591
onasled's Avatar
onasled
x
Old Sep 26, 2007 | 05:20 PM
  #592
mbcoops's Avatar
mbcoops
Did everything work out with the clutch?
mb
Old Oct 21, 2007 | 09:23 AM
  #593
onasled's Avatar
onasled
x
Old Oct 21, 2007 | 10:06 AM
  #594
MSFITOY's Avatar
MSFITOY
Wow...
Old Oct 21, 2007 | 10:47 AM
  #595
kapps's Avatar
kapps
Very nice!
Old Oct 21, 2007 | 03:27 PM
  #596
TheBlackBrian
looks not so great, but still more to do
http://ghmyc_1m.tripod.com/first_ran.wmv
I hope school was out of session at that point . Looking good Greg! I was wondering what was going on up there in new England.
-Brian
Old Oct 21, 2007 | 05:15 PM
  #597
snid's Avatar
snid
Yay!
I'm happy to see it running.
Old Oct 22, 2007 | 06:12 AM
  #598
onasled's Avatar
onasled
x
Old Oct 22, 2007 | 09:22 AM
  #599
Partsman's Avatar
Partsman
Legion_of_Doom
Great to see it on the ground and runnin' around. You must be antsy as all hell to get that thing on the track.
I'll be seein' you soon.
Old Oct 22, 2007 | 09:50 AM
  #600
JIMINNI's Avatar
JIMINNI
So whats the cooler on the back of the car?
