Road Racing Discussion Interested in taking your MINI road racing? Find out what you need to do to get your MINI ready!
Octane winter project
Old Aug 2, 2009 | 10:46 PM
  #126
justintime's Avatar
justintime
Originally Posted by J Propane
Just a regular welder or the pinch-weld type?
the pinch type
Old Aug 3, 2009 | 08:17 AM
  #127
curv872's Avatar
curv872
The factory painted front grill prevents good flow of fresh air into the engine bay. The accessory version is a lot better, but the ends are closed for some reason:
My guess is they are blocked to help cut down aerodynamic drag. While it doesn't amount to much, it does make a difference, especially considering that a large amount of aerodynamic drag is caused by this opening. Many new cars, including certain Mercedes and Hondas use electronically controlled radiator shields that open/close depending on engine cooling requirements. This is evident on the difference of drag between a Cooper (.35) and a Cooper S (.37) from the added hood scoop.
Old Aug 4, 2009 | 08:16 PM
  #128
dustinhxc's Avatar
dustinhxc
Clear tail lights and momo for the win!!!!!!!!!!!!!!
Old Aug 4, 2009 | 09:10 PM
  #129
J Propane's Avatar
J Propane
So the wiring is just about completed:
Main power wire + smaller wires (taillights/reverse lights, etc.)
Front portion:
Under the dash:
(I can't believe how many are still there...)
I guess we cut too many ground points. We had to add a couple:
Cut-off switch:
Now looks a little cleaner under the hood:
Intercooler and radiator+support installed:
Headlights (one still original :rolleyes)
While trying to fire it up, not much was happening. A little surprise:
No pump in the assembly!
Good thing we kept the one from the crashed tank:
And the final result:
http://www.youtube.com/watch?v=l64rf2AfVkc
Old Aug 4, 2009 | 09:19 PM
  #130
J Propane's Avatar
J Propane
Originally Posted by kurvhugr
I wasn't clear, I said lower grill but I was talking about the middle grill...the narrow one at the top of the fascia rather than the large, open lower grill at the bottom...
Yes something could be done there too. But the re-bar would have to get cut-up. Lots of work to push air in the rad.
Originally Posted by justintime
the pinch type
Sorry, not aware of any small version.
Originally Posted by curv872
My guess is they are blocked to help cut down aerodynamic drag....
Agreed.
We got a good deal.
  #131
kurvhugr's Avatar
kurvhugr
It is ALIVE!!!!
Old Aug 4, 2009 | 11:40 PM
  #132
UKCoopeR's Avatar
UKCoopeR
Sweeeeeeeeeeet!
Old Aug 5, 2009 | 07:15 AM
  #133
Bigshot's Avatar
Bigshot
And a GP intercooler to boot!
Looking good
Old Aug 5, 2009 | 04:08 PM
  #134
bean's Avatar
bean
Alain: the car is coming together beautifully. i wish that i had the *****/budget to do the targa newfoundland. i'm not sure that i could do it with an unlimited budget....the car looks great. you have set the bar high for my build.
greg
Old Aug 5, 2009 | 07:46 PM
  #135
J Propane's Avatar
J Propane
greg
Glad you enjoy. Only sharing so others can benefit.
Small stuff today:
Plate welded to the bullhorn for the timing transponder:
Useless bracket removed:
Coat of Krylon added:
Old Aug 7, 2009 | 08:36 PM
  #136
J Propane's Avatar
J Propane
The lower dash is now fitted:
Installation of the speedometer and dash pieces:
Switch for the heated windshield hanging (with LED light)
Testing the Aim dash:
We still need to fabricate the bracket to hold it.
Trying the upper dash panel. It will require a bit more trimming.
Basic brake bleed job to get some pressure:
The wires are now neatly tucked away with proper fasteners:
Front bumper re-bar installed:
The car as it sits for a trip tomorrow...
...covered:
A bit of work before leaving. Installation of the Intercooler cover:
Finalising installation of the transponder:
Tucking the wire away:
On the alignment rack:
The custom exhaust pipe ready for installation:
The center holding bracket installed:
Fitment a bit tight on the heatshield:
So we shimed the center bracket to lower the rear portion:
We might be a bit too low. Probably more work required here:
The V-Band holding the 2 sections:
The custom end section on the stock header. Since we have to remove the catalytic converter, we might as well make it better:
While there we used the factory tester to perform a proper bleed of the ABS components.
Random pictures of the rear suspension:
Old Aug 8, 2009 | 06:17 AM
  #137
UKCoopeR's Avatar
UKCoopeR
Looks like you guys are getting close to done!
Old Aug 8, 2009 | 07:02 AM
  #138
onasled's Avatar
onasled
No wideband 02 sensor Alain?
Old Aug 8, 2009 | 11:45 AM
  #139
Paulo's Avatar
Paulo
Nice build!
Car looks geat, the white interior and engine bay look so clean...What a pleasure to re-assemble all the wiring and parts when everything is so neat.
When will the debut be?
Congrats,
Steve
Old Aug 8, 2009 | 10:30 PM
  #140
J Propane's Avatar
J Propane
Awaiting quotation on one. We can alway use the one from the other car. No bung welded yet.
Old Aug 8, 2009 | 10:32 PM
  #141
J Propane's Avatar
J Propane
Congrats,
Steve
Car should be done tomorrow. Unless it needs a new power steering pump .
We most likely will bring it to Trois-Rivieres next weekend as a backup car.
Old Aug 10, 2009 | 12:37 PM
  #142
howsoonisnow1985's Avatar
howsoonisnow1985
Gosh, I wish I won the Lotto I would commission one of these!
Awesome build guys!
I wonder what the final weight of the car is?
Old Aug 11, 2009 | 10:29 PM
  #143
justintime's Avatar
justintime
isn't it easier for the radio button to be on the other side of the steering wheel?
Old Aug 12, 2009 | 04:06 PM
  #144
J Propane's Avatar
J Propane
Awesome build guys!
I'll PM you on Monday!
Old Aug 12, 2009 | 04:08 PM
  #145
J Propane's Avatar
J Propane
Yes, agreed. That's how we usually do it. Somehow it didn't seem to work with this round button. We'll try and see.
Old Aug 12, 2009 | 04:11 PM
  #146
J Propane's Avatar
J Propane
I guess we're a bit behind on posting progress. We tested the car last night and everything worked well, except that I feel like Arnold Shwarzenneger as the power steering didn't work. We'll figure this one out in Trois-Rivieres over the weekend
Old Aug 12, 2009 | 04:46 PM
  #147
bean's Avatar
bean
are you going to PM regarding the final weight or the size of the lottery required?
Old Aug 12, 2009 | 07:17 PM
  #148
J Propane's Avatar
J Propane
I'm not very good at calculation odds ...
Old Aug 12, 2009 | 09:54 PM
  #149
justintime's Avatar
justintime
have you tried it without powersteering at speed? might like it? any ill side effects besides being hard to turn at low speed?
Old Aug 13, 2009 | 04:07 AM
  #150
J Propane's Avatar
J Propane
Just hard to turn .
Kinda funny because it overamplifies the handling charachterics of the car. If you're not a sensitive driver, may be it's a good thing not to have one. And I'm sure one would get huge biceps by the end of the season if they don't die of exhaustion.....
