Bang! Rear suspension dropped
Old Mar 15, 2021 | 02:07 PM
  #26
Yep, got it and getting back to you with part soon.
Mike
Old Apr 17, 2021 | 02:46 AM
  #27
veggivet's Avatar
veggivet
Originally Posted by Wulfgar
Same thing happened to me and this is what i found. Not sure exactly what i need to do
Glad the OP had the situation resolved. Does anybody have a link to where I could find the part number for the large hexagonal steel bolt seen at the bottom of the top picture? Thanks!
Old Apr 17, 2021 | 04:25 AM
  #28
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Lower Shock Bolt, Item #2:
https://www.realoem.com/bmw/enUS/sho...diagId=33_1615
https://www.ecstuning.com/b-genuine-...h/33176760342/
Old Apr 17, 2021 | 05:44 AM
  #29
veggivet's Avatar
veggivet
Thanks njaremka!! 👍👍
How come the ecs tuning site says it doesn't fit a 2014 Paceman, though? It looks exactly like the part I need...
Old Apr 17, 2021 | 05:49 AM
  #30
njaremka's Avatar
njaremka
Alliance Member
Community Builder
The ECS compatibility filters are not always 100% correct. That's why I like to cross reference RealOEM.com for part numbers.
Old Apr 17, 2021 | 06:39 AM
  #31
veggivet's Avatar
veggivet
Makes sense. Thanks again for your help with this!
Old Apr 17, 2021 | 08:13 AM
  #32
13brian's Avatar
13brian
Bolt
Odd that RealOEM calls it a nut???
curious why you are in need of the Large bolt. Asking b/c I had not supported the bottom of shock when I removed it, turned out when reassembling, bolt would only thread back in about 5 turns. However, it was not my bolt that had damaged threads, a new bolt would not have worked. I had to buy a tap and rethread the hole in the cast aluminum bracket. I had to start tap from the outside, opposite of the side the bolt started into as the tap was starting in crooked, just like the bolt was doing, no matter how I was trying to start it. I was VERY happy I did not try to force the bolt, I can only imagine how much that large bracket would have cost.
Old Apr 17, 2021 | 08:24 AM
  #33
veggivet's Avatar
veggivet
Glad you were able to rethread with a tap. My mechanic said that isn't the way to go in my case, and I trust his advice. (He trusts me with his dogs' health ) I'm going for a used trailing arm assembly, which I think is what you meant when you said 'bracket'. You don't have to imagine how much they go for anymore! Stealership wanted over $700 for a new one, but I found a used one in good shape for $225. This should have a happy ending, as the dealership can get this bolt in a couple of days for me for less than $20.
The cause was a lot of rust/corrosion on the bolt itself. It started to strip the aluminum threads when my mechanic tried to loosen it up. He said it isn't a great idea to use a steel screw going into aluminum; the metals don't get along very well☹️
Subw00er
Suspension
23
Sep 13, 2017 09:19 PM
Aeromax
Apr 20, 2010 07:38 AM
scottab36
Suspension
Feb 7, 2009 02:17 PM
dominicminicoopers
Tires, Wheels, & Brakes
May 2, 2005 01:29 PM
