Not battery or alternator but grounding strap
Old Jun 29, 2019 | 07:40 PM
krlambrych@yahoo.com's Avatar
Exclamation Not battery or alternator but grounding strap
New to the forum. Posting an FYI. If you are having issues with a bad battery or alternator check your grounding strap / wire.
For the past few weeks my 2011 R60 S A4 had gremlins in the charging system. She seemed sluggish on start up. Then one day she did not start. Jump started her. I checked the alternator output at the battery terminals. It was 14 V. So I had the battery tested. It was okay. Put the fully charged battery in and she did not turn over. She would start after a jump. Then I checked the voltage at the battery. It was less than 12 when running. With my volt meter connected to the positive batter terminal I checked voltage at the engine side of the grounding strap. It was 14. I checked at the chassis side of the strap it was 12ish. If I wiggled the strap the voltage would go up but never all the way to 14. The strap looked ok but when I took it off it about crumbled in my hands from corrosion.
I bought a $6 12” battery cable to replace the grounding strap and now she starts and runs great. The MINI grounding strap was $50 from the local dealer - no thanks.
Old Jan 19, 2025 | 10:21 AM
yyj3869's Avatar
yyj3869
can I use this instead?
eljay
Feb 27, 2025 08:12 PM
Alkaidovich
35
Dec 29, 2024 07:09 PM
heemskn
Dec 9, 2024 01:59 AM
genik
Jun 26, 2014 07:35 AM
prb44t
Classic Mini Talk
18
Apr 3, 2012 05:13 AM
