Chrome Trim Peeling after 7-days
#27
Peeling trim
Well, I was hoping the OP was going to be an isolated incident but seems not to be. No heat where I live, but we have salt air that's tough on chrome trim. My Jeep's lasted much longer than I expected, but sounds like the CM's is lacking. I suppose I will have to deal with this (get my ride at the end of the month so can't compare my own yet) at some point. Not being able to see mine upclose, what do you think about just painting it? I've removed a lot chrome from my motorcycle as the weather attacks it and it's a look that i don't mind. How difficult/easy would it be to remove the trim and re-install it myself?
Last edited by OneTraveler; 06-07-2011 at 03:10 PM. Reason: minor grammatical error
#28
This is really disappointing. This type of quality issue is certainly avoidable at the factory. What also strikes as a big surprise/disappointment is the fact that Countryman's Chrome trim is simply a thin stripe of chrome tape put on to a plastic trim with adhesive, not even wrapped around. While this may actually be quite normal practice these days for non-premium cars, I certainly didn't realize that. Clearly, using chrome tapes instead of chrome plated trim is one of the cost cutting majors that fails big time.
#31
Went to my dealership today and the service manager ordered both sides for me. He told me he has never seen that problem on a MINI before. I told him how others on here are having the same problem. He said it might be a bad batch of parts.
Could it also be a aerodynamic problem? I've noticed on mine and other photos how the chrome is pushed down at an angle at corner of the trim piece. The angle looks about the same on both sides. Hmmmm......
#32
This chrome tape also appears so cheap that if I lived where it was cold out and received snow I would worry every time I have to use the ice scraper. Seems one hit to this with an ice scraper will result in a tear.
Seems all the thicker this is, is like Monokote for RC Airplanes. They should recall these pieces and make something else available that is more durable. Is very embarrassing driving around with my paper plate still and this tape peeling up or totally gone in one case.
#33
#34
I was hoping for the chrome to be available but an update from the parts dept is encouraging.
"Parts guys said that they came up with a bulletin and a new part number (showing to be available July 1)"
Maybe the chrome is being improved or at least changed back to the previous model year version.
#35
Was your dealership able to give you any part numbers?
#36
Picked up my Countryman Saturday, drove it 127 miles home in 98 degree heat and the chrome tape on both passenger side corners is coming off. Total of 6 of the moldings are short. One of those got short today in the sun so I expect them all to fail. Talked to my dealer today. They say they knew about it (thanks for warning me) and that there is a temporary fix (more tape) that they'll do now until the permanent fix is available. The permanent fix is aluminum molding and will be available "soon" I asked about the July 1st date and was told that it was highly unlikely that the new aluminum part would be manufactured and available for order by then. Love the car otherwise, this is my 3rd Mini, but this is absurd, that tape wouldnt even be acceptable on a model car. Find out anything from your end?
#37
#38
#39
I wonder if the fix of aluminum will look a little different. I am assuming the older MCS were aluminum and my wife's 2009 MCS is not tape and looks a little more like a brushed and polished aluminum.
Bottom line is it will not look right when the dealer only replaces one or two pieces around the car. I smell trouble ahead......
#40
#41
#42
#43
#44
Roadshow Mini in Memphis says no service bulletin yet. They say the July "fix" is temporary and that the alloy permanent parts are in the works but must be manufactured for the Countryman and will be a while. Love the vehicle otherwise, but this is SO incredibly disappointing.
Guess I should have just kept my appointment last Saturday to get the 5 new trim pieces put on . . . . .then I would already have the temporary solution.
#46
#47
Our Countryman seems to be having the same issue with the chrome trim along the rear of the hood. It seems to have been affected by the extreme heat we have been having lately. Dealer stated this is becoming a common occurance. They ordered me a complete new trim piece and will have it installed at the first service interval. I figured there would be some first year bugs to work out, but as long as they are covered, I'm cool with it.
#48
Yeah my trim it's coming off the front window, my ma said that mini usa has identified this as a problem with the manufacture. I don't know why this would be happening to the cm's only if this is the same product used on all the mc's but the dealer is going to replace it damn right u will replace it
#49
Ugh. Got some 3M automotive decal glue? and glued the pieces down before they started flapping in the wind. My MA said to just cut them off...yeah, right. Everybody with this ugly issue, please keep us posted on your replacement status. My dealer is telling me the fix available in July is still just said to be temporary. That there is no estimate on how long the permanent fix will take to manufacture. I don't get it, every Mini on that lot has the same chrome molding. Theyve been putting it on Minis since 2002. Why settle for such crappy work on the new Countryman?
#50
I took my CMS in this evening to get the two rear curved pieces replaced. We noticed that both drive and passenger door have shrinking chrome. My MA said may be able to get them in tomorrow, if not we'll have to bring it back at a later day to get them replaced. I'm also having a rattle in the drives side passenger door checked and having wheel locked installed.
My loaner car? A brand new 2011 MINI Cooper Hardtop (500 miles on it), they currently do not have any CMs as a loaner. It is silver with a white top. Not a S but still nice to ride.
I already miss my baby!
