R60 Winter tires are on
on
My winter wheels and tires are on too. Sport Edition wheels (not my first choice but price was right) and Michelin Pilot Alpin runflats. I reluctantly went with runflats due to the 200 plus miles treks from SF to Reno somethimes late at night and often in inclement weather. Runflats saved the night some time ago so I think it was the right choice given how I use this car.
Here is the diry CM with the clean convertible that is mothballed until the spring.
TSW Nurembergings in a matte bronze.
http://www.tsw.com/alloy_wheels_nurburgring.php
They're 17", 8" width, offset +35
Nokian Hakka R's
http://www.nokiantires.com/tyre?id=11949
215/55/17
- best winters you can buy imo.
Nokian Hakka R's
215/55/17
put my 16" mini oem rims with 205/70-16 dunlop winter tires on today
see for photos
https://www.northamericanmotoring.co...s-rim-fit.html
the winter tires are 27.3" OD vs the stock 225/45-18 OD of 25.9"
no rubbing noted, even at full lock
scott
see for photos
scott
Hi,
I too am looking at getting Blizzaks tires (Bridgestone Blizzak WS70 205/60-16) & black wheels put onto my 2011 MINI Cooper S Countryman ALL4 for winter.
My CM currently has the 17” 5-star spoke wheels.
I don’t know what the off-set is for my current wheels, but Tirerack.com recommends a wheel (for the above Blizzak tire) with an offset of 40mm.
The only solid black wheel that I’ve been able to find that comes close (& that I like) is the Touren TR9 (3190-6709MB).
It has an offset of 42mm.
How can I tell if this wheel will work on my CM?
-Sue
-Sue
here are the mini oem wheel specs for the countryman
16x6.5 offset 46
17x7 offset 50
18x7.5 offset 52
there is a wheel/tire size calculator here
https://www.northamericanmotoring.co...calculator.php
scott
16x6.5 offset 46
17x7 offset 50
18x7.5 offset 52
scott
Hi,
-Sue
-Sue
hi Sue
if you buy 205/65-16 tires, they will fit and your speedo will be spot on accurate plus the added sidewall height will give you more rim protection from potholes
scott
thanks again. i saw you mention that. the alternative wheel i have found is a 42 mm offset so i don't think it will spare me much in the dirt department. given that, i think i'll go with your setup!
Just had a set of WS-70 winter tires in 215/60-17 put on the All4. Fit fine with plenty of space in the wheel well for chains. Only problem was NTB destroyed one of the TPM sensors in the process. Seems like some of these places use a torque wrench to take out the cores for quick deflation.
