R60 Silicone Seal for Valve Cover Replacement
Old Mar 26, 2023 | 01:13 PM
gob15's Avatar
gob15
Hi all,
Does anyone have a diagram for or experience with the valve cover replacement for the 2012 R60? I have the new cover ready to go. I read on another thread about having to use silicone sealant. That user mentioned it all around the cover. Another thread on another site mentioned the manual only states near the "half moon" section to the left.
Any recommendations on the silicone seal and if it's needed throughout even though there is a rubber gasket that covers the entire perimeter?
Chris
Old Mar 26, 2023 | 07:01 PM
eljay's Avatar
eljay
Manual says to apply it all around. But I don't see a need, so I just did places where the gasket bends.
Old Mar 27, 2023 | 06:44 AM
gob15's Avatar
gob15
Thanks for that. That makes sense to me. So probably at the corners and the dip at the "half moon" bump.
Does that manual cover the 2012 R60 S as well?
Old Mar 27, 2023 | 09:28 AM
do72er's Avatar
do72er
From my own experience, no silicone seal needed. Very important is to torque bolts and do it in a correct order
Old Mar 27, 2023 | 03:34 PM
gob15's Avatar
gob15
This is great. Thanks!!
I guess this also begs the question...would adding any sealant do any harm or would it just be more than necessary?
Old Mar 28, 2023 | 03:36 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
It would only cause harm if you used too much and it oozed into the cam area and clogged the oil passages
Old Mar 28, 2023 | 06:36 AM
jawilli6's Avatar
jawilli6
I just had to do mine on a 2013. I hadn't read about using silicone and thus did not. It's early on, but mine is not leaking without any additional sealant.
Old Mar 28, 2023 | 08:21 AM
Yep, dealers dont use it, they use some red tack spray on the head connection. Thats what they did on my n14 MCS valve cover when replaced under warranty. I done two other valve covers myself. 1. TQ like the pattern above. 2. just make sure the surface on the head is clean and no gunk build up. Wipe with a clean towel and dont let gunk or dirt get into the engine head while cleaning.
Old Mar 28, 2023 | 08:26 AM
do72er's Avatar
do72er
Torque for the bolts is 10nm. Forgotten add this to a diagram
Old Mar 30, 2023 | 06:37 AM
gob15's Avatar
gob15
All great tips! Thanks to everyone. This place never disappoints and always generous with information. Does anyone have a specific high temp silicone they like to use? I may just place it on the half moon bend part. But only a thin amount.
Old Nov 17, 2024 | 09:28 AM
b.coate's Avatar
b.coate
Not sure if this the correct place to post this and I understand that this thread is a bit old. I just replace my valve cover and it started leaking from the PVC gasket. Not sure what it actually called but its not the membrane. I have included a image below.
Old Nov 17, 2024 | 09:35 AM
b.coate's Avatar
b.coate
Also if someone could tell me what the heck this thing is and how to put it back.
JohnnyWayne
May 11, 2022 11:35 AM
Jwanck11
17
Nov 13, 2019 07:05 AM
pepperstripes
Apr 7, 2015 01:22 PM
mysticturner
Feb 29, 2012 11:46 AM
