R59 Passenger window one touch up?
Old Dec 14, 2014 | 02:55 PM
  #26
scubbysnacks's Avatar
scubbysnacks
Here the response I just received.
We’re already working on many new codings for the Mini. In the next major coding update (beginning of January) a lot of the codings already possible on the E90 will be made available on the Mini as well :-)
Best regards from Munich
Arian
Old Dec 20, 2014 | 03:50 PM
  #27
barmybee's Avatar
barmybee
Passenger one touch up is NOT fitted because this is a safety feature to stop children/passengers being trapped by the window close mechanism. This system is now a standard feature on most modern cars, and has now moved on to auto open if the window glass comes into contact with pressure when closing.
Taken from the MINI owners hand book:
Closing
Danger of pinching
Monitor the closing process and make
sure that the closing path of the window is
clear; otherwise, injuries may result.◀
To close, press the switch upward. The window
closes until the switch is released.
Although not clear, this refers to the passenger side window control sequence, and not the drivers side control.
Drivers side is one touch open/close.
Hope this helps Roy
Old Jan 16, 2015 | 04:16 PM
  #28
scubbysnacks
Heres the full list of coding so far looks like they have been busy lots of good stuff added.
CAS: Comfort start
active
not active
BMWhat: Ignition key just has to be tapped once to start the engine after ignition is turned on.
CAS: Comfort eject
active
not active
BMWhat: Turn off the ignition with a long press on the start/stop button in order to eject the ignition key.
CAS: Comfort open using remote
active
not active
BMWhat: Press and hold the unlock button on the remote to open all windows and the sunroof.
CAS: Comfort close using remote
active
not active
BMWhat: Press and hold the lock button on the remote to close all windows and the sunroof.
CAS: Comfort close using door handle (comfort access)
active
not active
BMWhat: Use comfort closing features when locking with the door handle. This only works if comfort access is installed.
CAS: Comfort folding/unfolding for sideview mirrors
active
not active
BMWhat: When holding the lock/unlock button on the remote the sideview mirrors automatically fold/unfold. To activate this function please activate "Comfort folding/unfolding for sideview mirrors" in the "FRM" module.
CAS: Easy entry
active
not active
BMWhat: Press the unlock button once to unlock all doors. Press it again to lower the driver side window.
CAS: Easy entry Key 1
active
not active
BMWhat: Separate setting for "Easy entry" for key 1. Press the unlock button once to unlock all doors. Press it again to lower the driver side window.
CAS: Easy entry Key 2
active
not active
BMWhat: Separate setting for "Easy entry" for key 2. Press the unlock button once to unlock all doors. Press it again to lower the driver side window.
CAS: Easy entry Key 3
active
not active
BMWhat: Separate setting for "Easy entry" for key 3. Press the unlock button once to unlock all doors. Press it again to lower the driver side window.
CAS: Easy entry Key 4
active
not active
BMWhat: Separate setting for "Easy entry" for key 4. Press the unlock button once to unlock all doors. Press it again to lower the driver side window.
CAS: Selective central locking
active
not active
BMWhat: Unlocking the car once only unlocks the driver"s door. Unlocking it again unlocks the other doors, too.
CAS: Selective central locking Key 1
active
not active
BMWhat: Separate setting for "Selective central locking" for key 1. Unlocking the car once only unlocks the driver"s door. Unlocking it again unlocks the other doors, too.
CAS: Selective central locking Key 2
active
not active
BMWhat: Separate setting for "Selective central locking" for key 2. Unlocking the car once only unlocks the driver"s door. Unlocking it again unlocks the other doors, too.
CAS: Selective central locking Key 3
active
not active
BMWhat: Separate setting for "Selective central locking" for key 3. Unlocking the car once only unlocks the driver"s door. Unlocking it again unlocks the other doors, too.
CAS: Selective central locking Key 4
active
not active
BMWhat: Separate setting for "Selective central locking" for key 4. Unlocking the car once only unlocks the driver"s door. Unlocking it again unlocks the other doors, too.
CAS: Selective central locking - unlock fuel lid
active
not active
BMWhat: The fuel lid is also unlocked upon the first unlock, when "Selective central locking" is active.
CAS: Lock tailgate when car locked
active
not active
BMWhat: Tailgate cannot be unlocked, when car is locked.
CAS: Automatically lock vehicle Key 1
active
not active
BMWhat: Separate setting for "Automatically lock vehicle" for key 1. If no door or window has been opened two minutes after the car has been unlocked, the doors automatically lock.
CAS: Automatically lock vehicle Key 2
active
not active
BMWhat: Separate setting for "Automatically lock vehicle" for key 2. If no door or window has been opened two minutes after the car has been unlocked, the doors automatically lock.
CAS: Automatically lock vehicle Key 3
active
not active
BMWhat: Separate setting for "Automatically lock vehicle" for key 3. If no door or window has been opened two minutes after the car has been unlocked, the doors automatically lock.
CAS: Automatically lock vehicle Key 4
active
not active
BMWhat: Separate setting for "Automatically lock vehicle" for key 4. If no door or window has been opened two minutes after the car has been unlocked, the doors automatically lock.
CAS: Lock vehicle upon ignition
active
not active
BMWhat: Vehicle is locked, when ignition is turned on.
CAS: Unlock car when turned off
active
not active
BMWhat: Doors are automatically unlocked, when ignition key is ejected. Only works if "Lock vehicle at x kph Key 1-4" is activated.
CAS: Threshold speed for vehicle locking
2 kph / 1 mph
6 kph / 4 mph
12 kph / 8 mph
18 kph / 11 mph
24 kph / 15 mph
30 kph / 19 mph
BMWhat: Sets the speed at which the vehicle automatically locks all doors. For models other than E46 values 1 to 6 mean the following: 4 kph, 8kph, 12 kph, 20 kph, 24 kph, 28 kph To activate this function you need to activate "Lock vehicle at x kph" for the according keys.
CAS: Lock vehicle at x kph Key 1
active
not active
BMWhat: Automatically lock the vehicle at the set threshold speed when key 1 is used.
CAS: Lock vehicle at x kph Key 2
active
not active
BMWhat: Automatically lock the vehicle at the set threshold speed when key 2 is used.
CAS: Lock vehicle at x kph Key 3
active
not active
BMWhat: Automatically lock the vehicle at the set threshold speed when key 3 is used.
CAS: Lock vehicle at x kph Key 4
active
not active
BMWhat: Automatically lock the vehicle at the set threshold speed when key 4 is used.
CAS: Interior lights with remote
active
not active
BMWhat: Pressing the lock button on the remote, when the car is already locked, turns on the interior lights.
CAS: Panic mode remote
active
not active
BMWhat: Press and hold the "unlock trunk" button to trigger the alarm.
CAS: Unlock rear window
active
not active
BMWhat: Key unlocks rear window instead of trunk lid in touring models.
CAS: Unlock rear window key 1
active
not active
BMWhat: Key 1 unlocks rear window instead of trunk lid in touring models.
CAS: Unlock rear window key 2
active
not active
BMWhat: Key 2 unlocks rear window instead of trunk lid in touring models.
CAS: Unlock rear window key 3
active
not active
BMWhat: Key 3 unlocks rear window instead of trunk lid in touring models.
CAS: Unlock rear window key 4
active
not active
BMWhat: Key 4 unlocks rear window instead of trunk lid in touring models.
CAS: Unlock rear window with outside trunk lid button
active
not active
BMWhat: Outside trunk lid button opens rear window instead of trunk lid in touring models.
CAS: Unlock rear window with outside trunk lid button Key 1
active
not active
BMWhat: Outside trunk lid button opens rear window instead of trunk lid in touring models. Separate setting for key 1.
CAS: Unlock rear window with outside trunk lid button Key 2
active
not active
BMWhat: Outside trunk lid button opens rear window instead of trunk lid in touring models. Separate setting for key 2.
CAS: Unlock rear window with outside trunk lid button Key 3
active
not active
BMWhat: Outside trunk lid button opens rear window instead of trunk lid in touring models. Separate setting for key 3.
CAS: Unlock rear window with outside trunk lid button Key 4
active
not active
BMWhat: Outside trunk lid button opens rear window instead of trunk lid in touring models. Separate setting for key 4.
CAS: Unlock rear window with footwell switch
active
not active
BMWhat: Footwell switch opens rear window instead of trunk lid in touring models.
CAS: Unlock rear window with footwell switch Key 1
active
not active
BMWhat: Footwell switch opens rear window instead of trunk lid in touring models. Separate setting for key 1.
CAS: Unlock rear window with footwell switch Key 2
active
not active
BMWhat: Footwell switch opens rear window instead of trunk lid in touring models. Separate setting for key 2.
CAS: Unlock rear window with footwell switch Key 3
active
not active
BMWhat: Footwell switch opens rear window instead of trunk lid in touring models. Separate setting for key 3.
CAS: Unlock rear window with footwell switch Key 4
active
not active
BMWhat: Footwell switch opens rear window instead of trunk lid in touring models. Separate setting for key 4.
CAS: Prohibit engine start without brake
active
not active
BMWhat: Engine can"t be started when brake is not pressed.
CAS: Power windows after ignition off
active
not active
BMWhat: Power windows are active for another minute after ignition is turned off.
CAS: Arm/Disarm Anti-Theft Alarm System
Only with remote
With locks and remote
BMWhat: Anti-theft alarm system is armed/disarmed by locking/unlocking the car (1) with the locks and the remote or (2) only by locking/unlocking the car with the remote.
FRM: Continue window function when door is opened
active
not active
BMWhat: When the door is opened while its window is opening/closing, the window will continue opening/closing the window.
FRM: Mirror tilt 1/2
active
not active
BMWhat: Requirement for mirror tilt functions.
FRM: Mirror tilt 2/2
active
not active
FRM: Tilt mirror in reverse
active
not active
BMWhat: This function requires an installed LIN-Bus. Passenger mirror is tilted when switching into reverse gear. To activate this function activate "Mirror tilt", aswell.
FRM: Comfort folding/unfolding for sideview mirrors
active
not active
BMWhat: When holding the lock/unlock button on the remote the sideview mirrors automatically fold/unfold. May need additional coding of the "CAS" module.
FRM: Electrochromatic mirror dimming
active
not active
BMWhat: This function requires an installed LIN-Bus. Side mirrors automatically dim electrochromatic.
FRM: Seatbelt Hand-Over driver
active
not active
BMWhat: Automatic seatbelt hand-over for driver is active/inactive.
FRM: Seatbelt Hand-Over passenger
active
not active
BMWhat: Automatic seatbelt hand-over for passenger is active/inactive.
FRM: Flasher with bi-xenon
active
not active
BMWhat: Bi-xenon lamps are used for flasher.
FRM: Front fog lights and high beams not simultaneously
active
not active
BMWhat: Front fog lights are automatically turned off when activating high beams.
FRM: Front fog lights and flasher not simultaneously
active
not active
BMWhat: Front fog lights are automatically turned off when activating flasher.
FRM: Turn off interior lighting after 2 minutes
active
not active
BMWhat: Interior lighting is automatically turned off after two minutes.
FRM: Soft turn on/off for interior lighting
active
not active
BMWhat: Interior lighting is softly turned on and off.
FRM: Lights-on warning
active
not active
BMWhat: A warning is shown, when the driver"s door is opened while the lights are still on.
FRM: Hazard lights
standard
double
BMWhat: Hazard lights blink once or twice.
FRM: Crash lights
standard
double
BMWhat: Hazard lights blink once or twice upon an accident.
FRM: One-touch turn signal function
BMWhat: Number of turn signals when tapping the turn signal.
FRM: One-touch turn signal function Key 1
BMWhat: Number of turn signals when tapping the turn signal. Separate setting for "One-touch turn signal function" for key 1
FRM: One-touch turn signal function Key 2
BMWhat: Number of turn signals when tapping the turn signal. Separate setting for "One-touch turn signal function" for key 2.
FRM: One-touch turn signal function Key 3
BMWhat: Number of turn signals when tapping the turn signal. Separate setting for "One-touch turn signal function" for key 3.
FRM: Cornering lights with front fog lights
active
not active
BMWhat: Front for lights are used as cornering lights.
FRM: Cornering lights - addition 1
active
not active
BMWhat: Only change this coding, if you change "Cornering lights with front fog lights".
FRM: Brake force display 1/2
active
not active
BMWhat: Brake lights turn on or flash when braking hard. To activate this function, set "Brake force display 2/2" to "active".
FRM: Brake force display 2/2
active
active (alternative)
not active
BMWhat: Only change this function with "Brake force display 1/2".
FRM: Brake force display - minimum speed
20 kph / 12 mph
50 kph / 31 mph
BMWhat: Minimum speed threshold for brake force display.
FRM: Brake force display - blinking speed
slow
fast
BMWhat: Blinking speed for brake force display.
FRM: Brake force display - angel eyes
not active
on
flashing
BMWhat: Customization for angel eyes for brake force display.
FRM: Brake force display - outer brake lights
not active
on
flashing
BMWhat: Customization for outer brake lights for brake force display.
FRM: Brake force display - inner brake lights
on
flashing
BMWhat: Customization for inner brake lights for brake force display.
FRM: Brake force display - third brake light
not active
on
flashing
BMWhat: Customization for third brake lights (rear window) for brake force display.
FRM: Brake force display - tail lights
not active
on
flashing
BMWhat: Customization for tail lights for brake force display.
FRM: Brake force display - rear fog lights
not active
on
flashing
BMWhat: Customization for rear fog lights for brake force display.
FRM: Daytime running lights customization
Off
Individual
High beams
Low beams
Corona-rings/Angel-eyes (EU)
BMWhat: Customization of the daytime running lights. For Corona-rings/Angel-eyes also activate "Daytime running lights (Europe)".
FRM: Daytime running lights - front fog lights
active
not active
BMWhat: Use front fog lights as daytime running lights. To activate this function, set "Daytime running lights customization" to "Individual".
FRM: Daytime running lights - dimmed turn signals
active
not active
BMWhat: Use dimmed turn signals as daytime running lights. To activate this function, set "Daytime running lights customization" to "Individual".
FRM: Daytime running lights - sidemarker
active
not active
BMWhat: Use sidemarker as daytime running lights. To activate this function, set "Daytime running lights customization" to "Individual".
FRM: Daytime running lights - number plate lighting
active
not active
BMWhat: Use number plate lighting as daytime running lights. To activate this function, set "Daytime running lights customization" to "Individual".
FRM: Daytime running lights - tail lights
active
not active
BMWhat: Use tail lights as daytime running lights. To activate this function, set "Daytime running lights customization" to "Individual".
FRM: Daytime running lights - angel eyes
active
not active
BMWhat: Use angel eyes as daytime running lights. To activate this function, set "Daytime running lights customization" to "Individual".
FRM: Daytime running lights - brake lights
active
not active
BMWhat: Use brake lights as daytime running lights. To activate this function, set "Daytime running lights customization" to "Individual".
FRM: Daytime running lights - 3rd brake lights
active
not active
BMWhat: Use 3rd brake lights as daytime running lights. To activate this function, set "Daytime running lights customization" to "Individual".
FRM: Daytime running lights - high beams
active
not active
BMWhat: Use high beams as daytime running lights. To activate this function, set "Daytime running lights" to "High beams".
FRM: Daytime running lights - high beams brightness
off
low
medium
high
very high
BMWhat: Brightness for "Daytime running lights high beams".
FRM: Daytime running lights (Europe)
active
not active
BMWhat: Daytime running lights (Europe) active/not active.
FRM: Daytime running lights (Europe) Key 1
active
not active
BMWhat: Daytime running lights (Europe) active/not active. Separate setting for "Daytime running lights (Europe)" for key 1
FRM: Daytime running lights (Europe) Key 2
active
not active
BMWhat: Daytime running lights (Europe) active/not active. Separate setting for "Daytime running lights (Europe)" for key 2.
FRM: Daytime running lights (Europe) Key 3
active
not active
BMWhat: Daytime running lights (Europe) active/not active. Separate setting for "Daytime running lights (Europe)" for key 3.
FRM: Angel eyes brightness daytime running lights
off
very low
low
rather low
medium
rather high
high
very high
BMWhat: Brightness of Angel Eyes (Corona rings) for daytime running lights.
FRM: Angel eyes brightness standing lights
off
very low
low
rather low
medium
rather high
high
very high
BMWhat: Brightness of Angel Eyes (Corona rings) for standing lights.
FRM: Angel eyes brightness parking lights
off
very low
low
rather low
medium
rather high
high
very high
BMWhat: Brightness of Angel Eyes (Corona rings) for parking lights.
FRM: Brightness of Angel Eyes 1 - alternative
off
very low
low
rather low
medium
rather high
high
very high
BMWhat: Brightness of Angel Eyes. Only use this coding if the standard codings did not work!
FRM: Brightness of Angel Eyes 2 - alternative
off
very low
low
rather low
medium
rather high
high
very high
BMWhat: Brightness of Angel Eyes when low beams are active. Only use this coding if the standard codings did not work!
FRM: Brightness of Angel Eyes 3 - alternative
off
very low
low
rather low
medium
rather high
high
very high
FRM: Angel Eyes voltage monitoring 1/2
active
not active
BMWhat: Voltage monitoring for angel eyes. Might cause flickering of LED lights.
FRM: Angel Eyes voltage monitoring 2/2
active
not active
BMWhat: Deactivate with "Angel Eyes voltage monitoring 1/2" to disable flickering of LED lights.
FRM: Angel Eyes warning
active
not active
BMWhat: Warning for malfunction of angel eyes in the on board computer.
FRM: Sidemarker (US)
active
not active
BMWhat: Sidemarkers are permanently active. May need additional "Sidemarker (US)" functions set to "active" if available.
FRM: Sidemarker (US) brightness
off
very low
low
rather low
rather high
high
very high
BMWhat: Brightness for "Sidemarker (US)".
FRM: Sidemarker voltage monitoring 1/2
active
not active
BMWhat: Voltage monitoring for sidemarkers. Might cause flickering of LED lights.
FRM: Sidemarker voltage monitoring 2/2
active
not active
BMWhat: Deactivate with "Sidemarker voltage monitoring 1/2" to disable flickering of LED lights.
FRM: Turn signals front voltage monitoring 1/2
active
not active
BMWhat: Voltage monitoring for turn signals front. Might cause flickering of LED lights.
FRM: Turn signals front voltage monitoring 2/2
active
not active
BMWhat: Deactivate with "Turn signals front voltage monitoring 1/2" to disable flickering of LED lights.
FRM: Turn signals warning
active
not active
BMWhat: Warning for malfunction of turn signals in on the board computer.
FRM: Fog lights voltage monitoring 1/2
active
not active
BMWhat: Voltage monitoring for fog lights. Might cause flickering of LED lights.
FRM: Fog lights voltage monitoring 2/2
active
not active
BMWhat: Deactivate with "Fog lights voltage monitoring 1/2" to disable flickering of LED lights.
FRM: Low beams voltage monitoring 1/2
active
not active
BMWhat: Voltage monitoring for low beams. Might cause flickering of LED lights.
FRM: Low beams voltage monitoring 2/2
active
not active
BMWhat: Deactivate with "Low beams voltage monitoring 1/2" to disable flickering of LED lights.
FRM: Turn signals rear voltage monitoring 1/2
active
not active
BMWhat: Voltage monitoring for turn signals rear. Might cause flickering of LED lights.
FRM: Turn signals rear voltage monitoring 2/2
active
not active
BMWhat: Deactivate with "Turn signals rear voltage monitoring 1/2" to disable flickering of LED lights.
FRM: Braking lights voltage monitoring 1/2
active
not active
BMWhat: Voltage monitoring for braking lights. Might cause flickering of LED lights.
FRM: Braking lights voltage monitoring 2/2
active
not active
BMWhat: Deactivate with "Braking lights voltage monitoring 1/2" to disable flickering of LED lights.
FRM: Braking lights warning
active
not active
BMWhat: Warning for malfunction of brakinglights in the on board computer.
FRM: Tail lights voltage monitoring 1/2
active
not active
BMWhat: Voltage monitoring for tail lights. Might cause flickering of LED lights.
FRM: Tail lights voltage monitoring 2/2
active
not active
BMWhat: Deactivate with "Tail lights voltage monitoring 1/2" to disable flickering of LED lights.
FRM: Reversing lights voltage monitoring 1/2
active
not active
BMWhat: Voltage monitoring for reversing lights. Might cause flickering of LED lights.
FRM: Reversing lights voltage monitoring 2/2
active
not active
BMWhat: Deactivate with "Reversing lights voltage monitoring 1/2" to disable flickering of LED lights.
FRM: License plate lighting voltage monitoring 1/2
active
not active
BMWhat: Voltage monitoring for license plate lighting. Might cause flickering of LED lights.
FRM: License plate lighting voltage monitoring 2/2
active
not active
BMWhat: Deactivate with "License plate lighting voltage monitoring 1/2" to disable flickering of LED lights.
FRM: Optical confirmation for unlocking vehicle
active
not active
BMWhat: Optical confirmation for unlocking vehicle is active/not active.
FRM: Optical confirmation for unlocking vehicle Key 1
active
not active
BMWhat: Optical confirmation for unlocking vehicle is active/not active. Separate setting for "Optical confirmation for unlocking" for key 1.
FRM: Optical confirmation for unlocking vehicle Key 2
active
not active
BMWhat: Optical confirmation for unlocking vehicle is active/not active. Separate setting for "Optical confirmation for unlocking" for key 2.
FRM: Optical confirmation for unlocking vehicle Key 3
active
not active
BMWhat: Optical confirmation for unlocking vehicle is active/not active. Separate setting for "Optical confirmation for unlocking" for key 3.
FRM: Optical confirmation for locking vehicle
active
not active
BMWhat: Optical confirmation for locking vehicle is active/not active.
FRM: Optical confirmation for locking vehicle Key 1
active
not active
BMWhat: Optical confirmation for locking vehicle is active/not active. Separate setting for "Optical confirmation for locking" for key 1.
FRM: Optical confirmation for locking vehicle Key 2
active
not active
BMWhat: Optical confirmation for locking vehicle is active/not active. Separate setting for "Optical confirmation for locking" for key 2.
FRM: Optical confirmation for locking vehicle Key 3
active
not active
BMWhat: Optical confirmation for locking vehicle is active/not active. Separate setting for "Optical confirmation for locking" for key 3.
FRM: Activate follow me home lights
active
not active
BMWhat: Follow me home lights are active/not active.
FRM: Follow me home lights with remote
active
not active
BMWhat: Quickly press the "Open trunk" button twice to activate the follow me home lights. Under some circumstances the function "Panic mode remote" in the CAS has to be activated, too.
FRM: Cancel follow me home lights
active
not active
BMWhat: Follow me home lights are cancelled, when activating the flasher again.
FRM: Extend follow me home lights
active
not active
BMWhat: Follow me home lights are displayed longer, when activating the flasher again.
FRM: Follow me home lights duration
off
40s
90s
150s
240s
BMWhat: Duration of follow me home lights in seconds. To activate follow me home lights, activate the flasher, while the enginge is off.
FRM: Follow me home lights duration Key 1
off
40s
90s
150s
240s
BMWhat: Separate setting for duration in seconds of follow me home lights for key 1.
FRM: Follow me home lights duration Key 2
off
40s
90s
150s
240s
BMWhat: Separate setting for duration in seconds of follow me home lights for key 2.
FRM: Follow me home lights duration Key 3
off
40s
90s
150s
240s
BMWhat: Separate setting for duration in seconds of follow me home lights for key 3.
FRM: Welcome lights
active
not active
BMWhat: Welcome lights are turned on, when vehicle is unlocked. In order for the welcome light to work, the light switch in the car has to be set to "Auto".
FRM: Welcome lights Key 1
active
not active
BMWhat: Separate setting for "Welcome lights" for key 1.
FRM: Welcome lights Key 2
active
not active
BMWhat: Separate setting for "Welcome lights" for key 2.
FRM: Welcome lights Key 3
active
not active
BMWhat: Separate setting for "Welcome lights" for key 3.
FRM: Welcome lights Key 4
active
not active
BMWhat: Separate setting for "Welcome lights" for key 4.
FRM: Welcome lights duration
off
5s
10s
20s
40s
90s
BMWhat: Duration of the welcome lights in seconds.
FRM: Welcome lights - low beams
not active
turn on softly
turn on hard
BMWhat: Low beams are turned on with welcome lights.
FRM: Welcome lights - brake force display
not active
turn on softly
turn on hard
BMWhat: Brake force display is turned on with welcome lights.
FRM: Welcome lights - braking lights
not active
turn on softly
turn on hard
BMWhat: Braking lights are turned on with welcome lights.
FRM: Welcome lights - turn signals front
not active
turn on softly
turn on hard
BMWhat: Turn signals front are turned on with welcome lights. To activate this function you may need to additionally code "Sidemarker (US) brightness" to "very low" or higher.
FRM: Welcome lights - turn signals rear
not active
turn on softly
turn on hard
BMWhat: Turn signals rear are turned on with welcome lights. To activate this function you may need to additionally code "Sidemarker (US) brightness" to "very low" or higher.
FRM: Welcome lights - high beams
not active
turn on softly
turn on hard
BMWhat: High beams are turned on with welcome lights.
FRM: Welcome lights - number plate lighting
not active
turn on softly
turn on hard
BMWhat: Number plate lights are turned on with welcome lights.
FRM: Welcome lights - front fog lights
not active
turn on softly
turn on hard
BMWhat: Front fog lights are turned on with welcome lights.
FRM: Welcome lights - rear fog lights
not active
turn on softly
turn on hard
BMWhat: Rear fog lights are turned on with welcome lights.
FRM: Welcome lights - corner LEDs
not active
turn on softly
turn on hard
BMWhat: Corner LEDs are turned on with welcome lights. Due to the way LEDs work, it is not possible to softly turn them on.
FRM: Welcome lights - parking lights front
not active
turn on softly
turn on hard
BMWhat: Parking lights front are turned on with welcome lights.
FRM: Welcome lights - parking lights rear
not active
turn on softly
turn on hard
BMWhat: Parking lights rear are turned on with welcome lights.
KOMBI: Digital speedometer
active
not active
BMWhat: Digital speedometer is displayed in dashboard.
KOMBI: Digital speedometer permanent
active
not active
BMWhat: Digital speedometer is displayed permanently in dashboard.
KOMBI: Digital speedometer correction
active
not active
BMWhat: Active: corrected speed is displayed in dashboard Inactive: true speed is displayed in dashboard
KOMBI: Speedometer correction
active
not active
BMWhat: Active: corrected speed is displayed in dashboard Inactive: true speed is displayed in dashboard/nDoes not work on US models.
KOMBI: Speed limit warning
active
not active
BMWhat: Speed limit warning at 120 kph is active/not active.
KOMBI: GPS time correction
active
not active
BMWhat: Time of day is corrected by using GPS.
KOMBI: Ignition key warning
active
not active
BMWhat: Ignition key warning active/not active.
KOMBI: Gear shift indicator 1/2
active
not active
BMWhat: Gear shift indicator in the on board computer. To activate this function, also activate other codings for "Gear shift indicator".
KOMBI: Gear shift indicator 3/3
value 01
value 02
BMWhat: Only change with "Gear shift indicator 1/3".
KOMBI: Gear shift indicator key 1
value 01
value 02
BMWhat: Gear shift indicator for key 1.
KOMBI: Gear shift indicator key 2
value 01
value 02
BMWhat: Gear shift indicator for key 2.
KOMBI: Gear shift indicator key 3
value 01
value 02
BMWhat: Gear shift indicator for key 3.
KOMBI: Gear shift indicator key 4
value 01
value 02
BMWhat: Gear shift indicator for key 4.
KOMBI: Cruise Control speed display
0s
4s
6s
BMWhat: The set speed of the cruise control is shown for a couple of seconds in the on board computer.
KOMBI: Daytime running lights in OBC
active
not active
BMWhat: Turn daytime running lights on/off in on board computer. Might not work if an iDrive system is installed.
KOMBI: Threshold for low range warning
off
20 km / 12 mi
50 km / 31 mi
BMWhat: Threshold for acoustic low range warning due to low fuel level.
KOMBI: Threshold for tank reserve warning
6 litres
8 litres
10 litres
BMWhat: Threshold for tank reserve warning due to low fuel level.
Old Jan 17, 2015 | 01:49 AM
  #29
tmehanna's Avatar
tmehanna
That would all be helpful if BMWhat actually supported the Roadster, however it does not. No R59 among the list of vehicles and when I tried with R57 and R60 it said no compatible ECUs found
Old Jan 17, 2015 | 07:25 AM
  #30
TG.'s Avatar
TG.
Yes, that would be helpful
RocketUSA
Sep 15, 2015 07:45 AM
USA-RET
Sep 8, 2015 01:50 PM
Ntety
Sep 2, 2015 08:39 PM
hardy616
Sep 2, 2015 08:32 AM
