R58 LORDVDR: The ALL4 R58 Project
Old Jan 31, 2017 | 02:46 PM
  #176
Yes, would love to hear what that R58 sounds like now.
Old Jan 31, 2017 | 07:17 PM
  #177
LORDVDR's Avatar
LORDVDR
It's kinda awesome. I'll record something soon for sure!
Old Feb 1, 2017 | 01:07 PM
  #178
LORDVDR's Avatar
LORDVDR
JCW Brembo Big Brake Kit going on right now. So stoked!
Old Feb 1, 2017 | 02:06 PM
  #179
Much better, fills out that front wheel pretty good.
Old Feb 1, 2017 | 03:23 PM
  #180
LORDVDR's Avatar
LORDVDR
I'm going to break it in tonight and tomorrow. Drive around for a bit.
Old Feb 2, 2017 | 09:48 AM
  #181
TheBigNewt's Avatar
TheBigNewt
I like my brakes almost as much as the turbo. I've become sort of a stoplight racer. Take off fast, come in hot and brake! How did you get LORDVDR on the tires, stickon letters?
Old Feb 2, 2017 | 09:51 AM
  #182
LORDVDR's Avatar
LORDVDR
Love braking like that. LOLZ
I got the tire letters from @TredWear on Instagram. Their website is: TredWear
Ask for Mike and tell them LORDVDR sent you. You won't be disappointed.
Old Feb 2, 2017 | 10:54 AM
  #183
Did you get the flash? Follow the normal break in procedure like other pads and you will be good.
Also the first time you drive it, you will be like "wow those things work" as you push yourself into the seat belt.
Old Feb 2, 2017 | 11:40 AM
  #184
LORDVDR's Avatar
LORDVDR
I didn't drive it like a maniac. I'm going to ease into the brakes. Eventually...I'll be stopping on a dime.
Old Feb 2, 2017 | 07:51 PM
  #185
Mini-Moi's Avatar
Mini-Moi
Any All4 plans you'd be able to share?
Old Feb 3, 2017 | 01:54 AM
  #186
LORDVDR's Avatar
LORDVDR
Sure thing...
The logic is that the entire exhaust system has to be taken out and most likely the driveshaft and transfer case will run directly down the center. The exhaust will either have to be cut out of the side or on the hood somewhere. That's the basic logic that we are working with so far. As for the actual 4WD tech to go in? Probably going to need a donor MINI Countryman R60 for parts. Probably will need to fabricate and alter parts for sure.
Old Feb 3, 2017 | 07:21 PM
  #187
dube53's Avatar
dube53
There is a big gap between the fender well and fender trim.
You may not drive this car very often on public roads but how do you keep dirt and debris from going inside the fenders? Or, is it because the car is on a lift?
As for the JCW brakes, I am wondering why you waited so long to buy this upgrade for your project.
I cannot figure I could drive my Coupe without them.
Old Feb 3, 2017 | 07:39 PM
  #188
LORDVDR's Avatar
LORDVDR
The gap you see is partly because the vehicle is on the lift and also the metal has been rolled out and up to give the flares room to breathe. From time to time I clean out the pockets of debris. Nothing major goes in there. I drive in NYC and you'd be surprised what's on the roads these days.
I waited this long for the brakes because when I got the car originally the kit was WAY expensive. Now that I work for MINI, the discount I got plus the the retail price came down a lot, equals a perfect opportunity that I couldn't pass up.
My vehicle isn't a JCW. I bought an S and I've been building it up over the past few years.
Old Feb 3, 2017 | 08:24 PM
  #189
Mini-Moi's Avatar
Mini-Moi
Sure thing...
Any idea how compatible the Coupe tranny and Countryman/Paceman tranny is? They look pretty similar, but the SKU of the R60/R61 transmissions say they are only used for those models.
Where are you estimating the cost of parts/materials to land? It looks to be at least $5k.
Old Feb 3, 2017 | 08:47 PM
  #190
LORDVDR's Avatar
LORDVDR
That's a good question...have zero clue. I'm sure on some level it can be compatible...it just needs "persuasion". lol
Estimate will probably be more than that...given that I would probably have to get a decent salvage donor car and then figure out fabrication and then installation and labor. It's gotta be like 5K-10K.
Old Feb 3, 2017 | 10:14 PM
  #191
Mini-Moi's Avatar
Mini-Moi
Don't forget trying to implement the All4 system into the Coupe ECU/BCU...
I think eventually it might be easier to retrofit a different solution in that is fully mechanical. Either that or electric motors in the rear - either center mounted with axles or one mounted next to each hub.
I've always liked the electric route, but that's a lot of money to drop on something that I would have to develop on my own.
Old Feb 4, 2017 | 08:49 AM
  #192
LORDVDR's Avatar
LORDVDR
Oh that hasn't been overlooked either. There's always more than one way to do figure stuff out. I'm not even close to the point of beginning this aspect of modifications yet. It's probably a few years away. I'm open to any and all opportunities.
Old Feb 4, 2017 | 10:44 AM
  #193
Tigger2011's Avatar
Tigger2011
Alliance Member
When we put an R60 All4 engine in an R56 the R60 wire harness includes an extra wire from the ECU to the PTO transfer box as I recall. Can't remember if the signal is VSS or load that tells the transfer gear box to vary torque to the rear. Pretty sure it was vehicle speed though. Wish I had pulled the All4 engine myself so I could have had pictures.
Maybe one of our brethren here with an All4 will climb underneath and snap some shots of the PTO interface.
Old Feb 4, 2017 | 10:53 AM
  #194
LORDVDR's Avatar
LORDVDR
Wow cool. Yeah that would have been super awesome.
Old Feb 6, 2017 | 01:40 PM
  #195
LORDVDR's Avatar
LORDVDR
Got the psi up to 18 today on the highway. Like a completely different car...for the better. Wow...just wow.
Old Feb 6, 2017 | 02:10 PM
  #196
Bnourai's Avatar
Bnourai
man i can't find any YATT fender flairs...
Ben
Old Feb 6, 2017 | 03:28 PM
  #197
LORDVDR's Avatar
LORDVDR
What about Aesthetic MINIs? Aesthetic MINIs
Old Feb 6, 2017 | 04:17 PM
  #198
Bnourai's Avatar
Bnourai
sold out
i have the same xxr's on my car. r56 s
Old Feb 6, 2017 | 05:19 PM
  #199
LORDVDR's Avatar
LORDVDR
Ahhhh I see. They usually restock them every few months. They should have them again soon. Send them either an email or DM on Instagram and ask for Eddie. Tell him "LORDVDR" sent you.
Old Feb 7, 2017 | 04:15 AM
  #200
Bnourai's Avatar
Bnourai
I have sent an email, will do one more.
Thx
Ben
