R58 Embarrassed to have a justa for first time
Old May 25, 2013 | 08:21 PM
  #26
dannyhavok's Avatar
dannyhavok
Originally Posted by rkw
FYI, your Justa coupe has LOTS more torque than a 1st gen Justa.
Good point. I did an HPDE day in a 2012 R56 Cooper and it pulled harder than my R50 did pre-tune, for sure.
Old May 26, 2013 | 08:04 AM
  #27
Wattage13's Avatar
Wattage13
there isn't a high enough octane to give you the kind of torque the OP is wishing for.
just have to be comfortable driving 3000 to 6000k
Old May 26, 2013 | 10:52 AM
  #28
astroBlackMetallic_Mini's Avatar
Originally Posted by Cruzer214
So yesterday I'm driving home in my super fast looking coupe on a two lane highway when I go to pass two cars. There is Subaru station wagon behind me that's dying to pass as well. I find my chance to pass and downshift and gun it, as I'm passing I look thru my rear view mirror and see the flipping station wagon on my bumper trying to push me off the road! Is it just me or should the justa at least have 150 hp ? There is zero torque in my car until I am above 5000 rpms. The strange thing is when I get loaner cars with automatic trans they seem a lot faster then my manual trans... Weird
Sent from my iPad using NAMotoring
Don't be afraid of the redline. It's there for a reason; that's your top end of what the engine can safely handle! The ecu won't let you hurt the car. Since you don't have a turbo you'll need every rpm you can get. It'll be ok to whomp on the thing, I redlined my 87 celica regularly in every gear for Years with no issues, and sold her running just fine before I got my mini.
Next, get a high flow air filter, and run some injector cleaner through the engine. Redlining the car is OK people! It's GOOD for the car!
Old Jun 1, 2013 | 11:18 AM
  #29
Cruzer214's Avatar
Cruzer214
So the ecu will not let the motor go over red line?
Old Jun 1, 2013 | 11:19 AM
  #30
Braminator's Avatar
Braminator
You got it.
Old Jun 1, 2013 | 11:27 AM
  #31
Cruzer214's Avatar
Cruzer214
Well that's good news because I was constantly looking at the tach to make sure she wasn't going to blow!
Old Jun 1, 2013 | 11:32 AM
  #32
Braminator's Avatar
Braminator
Don't look and watch and feel how the ECU will shut you down when you hit redline.
Old Jun 1, 2013 | 11:36 AM
  #33
danjreed's Avatar
danjreed
The ECU shuts down fuel, spark, and adjusts timing to protect it from over reving..
Old Jun 1, 2013 | 03:22 PM
  #34
hsautocrosser's Avatar
hsautocrosser
Um, the speed limiter only works when accelerating, not when downshifting, yes?
Old Jun 1, 2013 | 04:05 PM
  #35
danjreed's Avatar
danjreed
Um... Correct.
You can over-rev the engine in a manual while downshifting.
$$$$$$ + a trail of parts on the road..
Old Jun 1, 2013 | 06:29 PM
  #36
JoanieB's Avatar
JoanieB
My Winnie had no trouble passing even when the speed limit was 80 (in Utah) but you do have to be willing to push them higher. I'm finding the joy in the higher rpms. Go out somewhere safe, and play with what your engine can do if you get serious about it! Plus, the sport button is your friend, changes your linear acceleration to progressive, so the pressure that you put on the pedal gets multiplied!
Correct me if I am wrong, please, but the way it was explained to me is that generally the accelerator is a 1:1 ratio, so your foot moves, and the pedal gives the same amount of gas as your movement. But in Sport, that ratio goes up exponentially with more pressure, so you get a greater response in acceleration. Not more POWER, but more RESPONSE. Is that right, oh Gurus?
Also, the ECU senses your driving style, and adjusts to it. So if you tend to start out with more zest, the engine control unit comes to expect that and deliver it. Some people clear their ECU before tracking their car, someone said, especially if it is a commuter car/daily driver. So the car starts again, with a different driving style, while tracking. Is that the case?
Old Jun 1, 2013 | 09:54 PM
  #37
NewCooperFanatic's Avatar
NewCooperFanatic
Originally Posted by danjreed
Um... Correct.
That's called the money shift lol
Old Jun 1, 2013 | 10:48 PM
  #38
ZippyNH's Avatar
ZippyNH
Boom!!!
Your mini is no cellica.....
Old Jun 1, 2013 | 11:03 PM
  #39
dannyhavok's Avatar
dannyhavok
Originally Posted by ZippyNH
Boom!!!
I redline my R50 all the time, and it's been very reliable for the 35,000KM I've been thrashing it around. Maybe the R56's are more fragile, but I doubt it. Nothing wrong with hitting the rev limiter... it's there for a reason. If it wasn't within safe tolerance, it would be at a lower RPM... right?
Old Jun 1, 2013 | 11:27 PM
  #40
Boom!!!
Not quite understanding this... You saying a mini engine is not as good as a 20+ year old Toyota engine design?
Old Jun 2, 2013 | 06:21 AM
  #41
ZippyNH's Avatar
ZippyNH
Love my mini but....
180,000 miles on one is an accomplishment....
270,000+ or even 350,000 miles is kinda the norm on a honda or Toyota with care....even thraehing....engines are a bit more mature.
Old Jun 2, 2013 | 09:04 AM
  #42
ashchuckton's Avatar
ashchuckton
Called CARBON BUILD_UP!!
get it cleaned...bet it is causing you a power loss...maybe..then again the Subie likely has a turbo.....
Justa Cooper's do not suffer from carbon build up. They are not direct injection engines. At each oil change pour a bottle of Chevron Techron in the tank. Keeps the intae tract nice & clean.
Edit
I justa started reading this thread. Sorry if this has been covered a few times.
Old Jun 2, 2013 | 10:35 AM
  #43
TREX's Avatar
TREX
With small high reving engines you need to learn to keep them within thier power band for performance and as long as you don't go beyond the designed limits it doesn't hurt a thing.
Of course for just crusing down the highway for economy the highest gear and lowest rpm works best.
Wife used to have a little non-turbo PT Cruiser and it was a fun little car to drive, plenty of pep as long as you kept it in the power band and took trips through the rocky mountain pass's without a problem.
Old Jun 2, 2013 | 11:58 AM
  #44
danjreed's Avatar
danjreed
^ ^ this.
I don't see the point of going to redline once you pass the peak HP and Torque of the motor.
It's not a Honda..
Old Jun 2, 2013 | 11:59 AM
  #45
danjreed's Avatar
danjreed
Just because your audio system goes to "10" does not mean it sounds best... Or is good for it.
Old Jun 2, 2013 | 01:00 PM
  #46
byron h's Avatar
byron h
Cruzer214
I also have a manual transmission and almost 20,000 miles. I suggest you use a top-tier premimum gasoline as recommended by MINI. Also change the oil at 8,000 miles as MINI is now recommending. I keep the revs over 2,000 rpm for normal driving and over 4,000 rpm for spirited driving. I have never added any additives and my engine seems to respond very well. I rarely have to down shift to pass and have plenty of power when needed. The top tier gasolines and frequent oil changes should keep your engine clean and responsive.
Morris, 2011 MC, PW/B
Old Jun 2, 2013 | 02:33 PM
  #47
Cruzer214's Avatar
Cruzer214
I don't there are any top tier stations in New Jersey unfortunately. I drive approx 23,000 a year so the one good move I made was not getting an S. hopefully I didn't make a mistake in buying a mini, time will tell!
  #48
Cruzer214's Avatar
Cruzer214
I don't think there are any top tier stations in New Jersey unfortunately. I drive approx 23,000 a year so the one good move I made was not getting an S. hopefully I didn't make a mistake in buying a mini, time will tell!
Old Jun 2, 2013 | 02:49 PM
  #49
rkw's Avatar
rkw
Surely some of these brands are sold in New Jersey: http://www.toptiergas.com/retailers.html
Old Jun 2, 2013 | 02:50 PM
  #50
dannyhavok's Avatar
dannyhavok
My sound system goes to 50
I'm inclined to trust the engineers who determined where the safe rev limit for the engine is.
