R58 New Coupe S with rear rattle clunk-clunk mystery?
Old Nov 7, 2012 | 10:00 PM
  #26
Kevlars's Avatar
Kevlars
It's the plastic pieces from the small window. Just had the dealer pull it apart and put cloth tape. Problem solved. As to the trunk issue tape no work on coupe. It will for about a month. The issue is that the hatch is much ....much heavier than the non coupe. The lock needs to be adjusted with the rubber stops. I was at the dealer for 3 hours today getting that fixed. Had the shop Forman tell me that he has had more coupes in for that issue.
Just letting u all know.
Old Mar 24, 2013 | 10:13 AM
  #27
seamonkey420's Avatar
seamonkey420
random side note for those w/clunks...
i have a 2013 coupe w/the JCW spoiler and have not had a single rattle from my trunk minus one time. however i found out the rattle was because i had tied down a plastic shovel and not my mini when i first heard it i was very worried i'd have rattles but nope, just what i had in my boot.
Last edited by seamonkey420; Apr 18, 2013 at 05:10 PM. Reason: fixed problem, was not related.
Old Mar 25, 2013 | 07:47 AM
  #28
powerbook76's Avatar
powerbook76
mine still makes the noise.
probably more annoyance than anything.. also makes the car "sound" a lot cheaper than its 40k price tag :(
haven't had a chance to stop by the dealer, just waiting for 10,000 miles service so i can request for that to be fixed.
i guess my laziness is still "louder" than the clunk noise since i been just ignoring via blasting music.
Old Mar 27, 2013 | 05:31 PM
  #29
PHL_FLYERS's Avatar
PHL_FLYERS
I have a 2012 Coupe that has noise in the trunk. Was in the shop 2 times. Once they replaced the lock assembly and the other time they replaced the Latch. It still rattles. Only thing that stops the rattle is tape. I find it stupid that you have to use tape to stop rattling on a car that was purchased new and still hasn't had it's first schedule service.
Old Mar 30, 2013 | 06:55 AM
  #30
rosvick's Avatar
rosvick
I've found this to (sort of) help:
After adding a piece of tape to the striker, open the hatch, and screw all four bump stops IN, so they're "retracted" as much as possible. Close the hatch, and look through the body gap at the bump stops and their resting points on the body. Note the distances between all four.
Open the hatch again, and twist them all out a little bit, then close the hatch and note the distances again. Continue this until the four bumpers are just barely touching the sheet metal, and I mean *barely*. Each one might be twisted out a different amount, but that's fine. This is where the hatch wants to rest by default.
Now, open the hatch again, and twist each bumper one half rotation. Go for a drive, and see if that stops it. If it doesn't, keep rotating each bumper about a quarter turn, and then keep driving. Eventually, you'll find the right tension on the bumpers to keep the hatch from moving around too much.
It's a pain in the ***, but it works in the end. It took me a few days to get it right, but I'm now driving around in welcome silence.
Old Apr 17, 2013 | 05:07 PM
  #31
seamonkey420
well, my coupe started making this same noise after i got about 2000 miles on her. gonna try the adjustment first and then possibly take into dealer to look at.
should have known after replying to the thread i'd see it.. hehe.. thanks all for the tips!
UPDATE: well, realized my rattle was caused by having the hatchback cargo net attached to the shelf in the back and in turn it was bouncing off my pelican case i have my Readyset Solar Charger in. random coupe question; can we put Cargo nets in the back like in the Hatchback? i bought and use the 3 net pack from Mini for the R56 but there doesn't seem to be any real place to hook the top of the triange side nets. i'll post a pic and new thread later tonight (and search for prev topics too)
Last edited by seamonkey420; Apr 18, 2013 at 05:10 PM. Reason: updated w/rattle source
Old Apr 29, 2013 | 06:49 PM
  #32
coasterguytx's Avatar
coasterguytx
I'm so glad I found this thread... I looked for that rattle FOREVER. Next time it does it, I'll play with the rubber thingies.
Shouldn't have to worry about it, though, since my Roadster is due here next week! WOO HOO!
TREX
Nov 2, 2019 07:31 PM
FrostyFox
Oct 28, 2015 02:06 PM
alistaircookie
Oct 8, 2015 10:52 AM
artguy
R58 :: Coupé Talk (2012+)
Aug 30, 2015 07:56 PM
iclancy82
Aug 11, 2015 09:35 AM
