R58 Valentine One - Visor Mount around Reaerview Mirror
Old Mar 19, 2012 | 02:46 PM
  #26
Xeraux's Avatar
Xeraux
Aaaandd... Done.
Old Jun 19, 2012 | 10:52 AM
  #27
mid_life_crisis's Avatar
mid_life_crisis
Aren't those of you mounting Valentines up really high in a coupe worried about blocking the rear facing receiver because of the baseball cap's bill?
Old Jun 23, 2012 | 09:52 AM
  #28
DAVESTER's Avatar
DAVESTER
Nope, it reads the rear just fine
Old Jun 24, 2012 | 09:04 AM
  #29
mid_life_crisis
I'm "this close" to pulling the trigger on a 2012 Coupe but I'm concerned about something else to do with the mirror. There are threads on this for other Minis but their mirrors mount differently.
Does anyone else have a problem lining up the mirror to see more than just a couple of car lengths back? It seems like it is set too high on the windshield.
Old Jun 24, 2012 | 12:16 PM
  #30
BillTheCat's Avatar
BillTheCat
My opinion is that the mirror is clearly mounted too high to be of much use. You may want to go have a sit or test drive in one & see what you think, though. Be sure to put the spoiler up & have a peek that way, too, if you're concerned about rear visibility.
I occasionally duck down to let me see a little further out the back, but rely primarily on my side mirrors. Honestly, it's not that huge of a bother to me, although it might annoy the heck out of someone else.
Old Jul 13, 2012 | 08:10 AM
  #31
alexroet's Avatar
alexroet
I installed my V1 yesterday... mounted it above the mirror, to the left, with the suction cup mount (why wouldn't you want to use the suction cup mount? I don't see the problem with it.) the only issue I've noticed is that if I put the visor down it hits the V-1. Will see if that's a big enough issue to move it to the right side. Works great. Used an add-a-circuit into the fuse for the lighter (I forget which number). Only thing is the fuse door doesn't close over it very well.
Old Jul 13, 2012 | 10:24 AM
  #32
mid_life_crisis
I sprung for the optional OBD port connector that powers it and lets the V1 know when the car's speed is below a set threshhold so it uses "mute" volume level. I'll have to look into how to thread the wire up to the mirror.
Old Jul 13, 2012 | 10:29 AM
  #33
alexroet's Avatar
alexroet
I just tucked it behind the trim all the way around the windshield... it hides completely
Old Aug 3, 2012 | 10:15 AM
  #34
adcam's Avatar
adcam
This looks like a nice option for my V1. It plugs into the OBD II port and the the V1 draws its power from it.
http://www.valentine1.com/savvy/?ex=...mie6t5-128ifgc
Old Aug 3, 2012 | 12:02 PM
  #35
mid_life_crisis
That's the piece I mentioned three posts back. It works great. I've also got the remote display for the dash area and the carry case for going on vacations. Good stuff.
Old Aug 3, 2012 | 12:10 PM
  #36
adcam's Avatar
adcam
mid life, where did you end up wiring the V1?
woodstudio
Mar 15, 2020 08:28 AM
techgearpro
Jul 23, 2019 07:09 PM
dyeLucky
Sep 11, 2015 10:41 AM
F55MidnightBlackCooperS
Sep 3, 2015 04:02 PM
