R57 Rear woofer replacement?
Old Aug 24, 2023 | 04:31 PM
wkearney99's Avatar
wkearney99
I have a 2014 r57 convertible s with the Harman kardon speaker system and the right rear woofer has failed. What's involved with replacing it? And are there any other alternatives to OEM that are known to be drop in replacements?
Old Aug 25, 2023 | 07:03 AM
https://www.realoem.com/bmw/enUS/sho...diagId=51_7163
H/K version https://www.realoem.com/bmw/enUS/sho...diagId=65_1677
Rear side panel and pop that out, if i remember right you cant get it on the convertible r57 with just the speaker cover, see if you can get it from the cover. The R57 with H/K acuatlly has two speakers, a woofer and a tweeter system in each panel.
Up to 9/2009 H/K rear woofer https://www.ecstuning.com/Search/Sit...h/65139141656/
9/2009+ H/K rear woofer https://www.ecstuning.com/Search/Sit...h/65139194843/ ( the one you need)
Old Aug 25, 2023 | 09:19 AM
wkearney99's Avatar
wkearney99
Does the circular cover on the woofer speaker just pop loose from the front?
Old Aug 25, 2023 | 10:55 AM
Held in with a clip
# 13
Looking at it again with used pieces, it has 6 of those clips on each side. Might be better just to remove the whole panel.
More DIY: https://www.northamericanmotoring.co...-speakers.html
Old Aug 25, 2023 | 04:19 PM
wkearney99's Avatar
wkearney99
Ah, so there's 6 tabs inside/under the round cover. I can't tell from the 2nd picture if they release inward (which might allow release from the front) or outward (which would require access from the reverse. I'll see if the thin spudgers I've got let me get any kind of release on them from the front.
Because otherwise it's "seats out"?
Old Aug 28, 2023 | 07:24 AM
Yep use that as a guide.
leftfield6
Jan 4, 2018 02:59 PM
hulagirl43
Jun 26, 2014 10:26 AM
MiniDaMoocher
May 18, 2008 07:07 AM
ImagoX
Jan 9, 2007 07:32 PM
