R56 A solution to the missing temp gauge problem
Old Mar 28, 2007 | 07:20 AM
  #26
Loony2N's Avatar
Loony2N
Originally Posted by th3118
You might consider these:
DashHawk
http://new.minimania.com/web/Item/NM.../InvDetail.cfm
or
http://www.scangauge.com/
Both just plug into your OBDII port.
This may be a dumb question, but do those units plug directly in, or is there a wire, so that you can mount the unit elsewhere?
Old Mar 28, 2007 | 07:36 AM
  #27
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
Yes, both come with cables so you can mount them anywhere on your dash. You could also unplug them and move them from one car to another.
Old Mar 28, 2007 | 07:55 AM
  #28
Loony2N's Avatar
Loony2N
ty, th! Looks like I have another purchase coming up!
Old Mar 28, 2007 | 08:16 AM
  #29
Robin Casady's Avatar
Robin Casady
Please give us a full report when you get it.
Old Jul 19, 2008 | 08:28 AM
  #30
Don Russell's Avatar
Don Russell
ALTA has a BOOST g that will give you boost amd vacum
Old Jul 19, 2008 | 08:38 AM
  #31
pilotart's Avatar
pilotart
Boost and Vacuum will be shown on one gauge, above zero is boost amount and should show below zero at low engine load.
Turbo LeBaron had many functions that required vacuum
(like Power Brakes and A/C Ducting doors) and there was a check valve to hold the vacuum (in PB Accumulater) and if it leaked,
A/C Doors would move under high boost (and there could be a difference in brake response)
Kimolaoha
Jul 5, 2023 01:04 PM
tylewis
Aug 18, 2015 06:53 AM
mini yellow-haa!
Aug 13, 2015 11:18 AM
Minii cooper bean
Aug 11, 2015 02:10 PM
