The wheels probably won't work. Virtually all MINIs have wheels with holes for 12mm wheel bolts. Sometime around June 2006 the factory began mounting the wheels to the cars with 14mm wheel bolts. So not only are the wheel bolts themselves different (different size), but on the 2007 they have larger holes in the wheels for the wheel bolts. This would also mean different hub, different brake discs, and different wheel locks, among other things. Finally, the lug bolt removal tool in the took kit should be different between 2006 and 2007.
Those are just a few of the things I can think of right now.
Anybody got any ideas (theoretical, of course) how to press that MCS scoop into service??
The new MCS may be one of the only cars where a remote-mount radar detector can be as sensitive as one mounted in the window, owing to the high mounting location available in the scoop.
Cheers,
Bruce
motorbruce
The wheels are no different as far as the cars fitted with the bigger bolts. Just the bolts are different (and accompanying fitment hardware).
