R56 2013 R56S Stall While Driving But Fine While In Idle
Old May 11, 2026 | 01:28 PM
  #26
freakonforfatty1's Avatar
freakonforfatty1
Originally Posted by Maybe, maybe not
Good questions. The oil pressure sensor and oil volume/condition sensor are functionally distinct sensors.
Yes, including the O2 sensor codes. The alternator is on the BSD bus network. Taking down the BSD bus prevents proper alternator charging, which in turn leads to a general under-voltage condition.
What causes these problems? The oil volume sensor in the oil pan wicks engine oil that creates a local sensor short and that can travel along the wires all the way to the DME connectors and DME. It's a well known BMW/Mini issue.
So, do you suggest replacing the oil sensor? It isn't very expensive.
Old May 11, 2026 | 02:04 PM
  #27
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
Replacing the bad sensor must done eventually, but it may be the last step of three steps because the oil pan must be dropped to replace the sensor.
The recommended first step is to disconnect the battery and then the three DME connectors. This is done to check whether engine oil has already wicked into the DME connectors and DME. The mentioned O2 sensor codes suggest that you may find oil in the DME connectors and the DME.
The recommended second step is to unplug the oil sensor connector located at the rear of the block and to check for oil wicked into that connector as well. There may also be a useful diagnostic test to perform here.
This is just an overall summary. I can provide more details as needed.
kwak1526
Dec 28, 2021 12:48 PM
maidi3000
Apr 3, 2019 04:11 AM
s0udwrench
Jul 8, 2015 01:35 PM
Tslatt
Mar 26, 2015 10:29 AM
bluebird85
Cooper (non S)
Mar 30, 2014 03:34 PM
