Cooper (non S) Modifications specific to the MINI Cooper (R50).
Loss of Power
Old Mar 30, 2014 | 10:13 AM
bluebird85's Avatar
bluebird85
Loss of Power
I have a 2010 mini hardtop with 45,000 miles. Lately I have been experiencing loss of power. Last night I was driving and I could not get my car to go over 40 mph. I was flooring the gas, but just would not go over 40. Also, when idle, the car makes a shuttering feeling about every 30 to 60 seconds. My check engine light has not come on, so I am confused. Has anyone experienced anything similar? or have any suggestions?
Old Mar 30, 2014 | 11:05 AM
RA082324's Avatar
RA082324
have you ever replaced your spark plugs, plug wires, or battery? have you serviced your coil pack (check lead #3 for wear)
are you keeping up with oil changes or noticing any spots on the ground indicating leaks that may cause low levels if unattended?
are you using the proper 93 octane fuel? ran some lucas in with a tank of gas.
have you ever cleaned or replaced your air filter?
those are good places to start if theres no cel.
a worse case could be faulty map sensor or o2 sensor, but those would usually cause a cel and dont usually fail that early in mileage.
Old Mar 30, 2014 | 12:51 PM
bluebird85's Avatar
bluebird85
Thanks for the info. I do use 93 octane, keep up with oil change, and I also did a fuel injector cleaning about 5,000 miles ago. The loss of power is intermittent. I tried driving it today and it was still a bit sluggish. but was able to drive at 60 mph.
Old Mar 30, 2014 | 03:34 PM
RA082324's Avatar
RA082324
well thats good. at this point if there is still no cel after continuous driving, i would rule out the o2/map sensors.
if youve never replaced the spark plugs, i would do that at this point even if they arent the cause if the problem.
the air filter is relatively easy to check, and can be easily replaced as well. another thing i would consider doing if its never been done, again whether its causing the problem or not.
shorenetworks
Nov 4, 2019 06:18 PM
twriter
Oct 2, 2015 03:14 PM
paul7878
Sep 14, 2015 07:44 AM
Emnotek
Sep 11, 2015 04:16 PM
ou812_tugger
Sep 5, 2015 03:24 PM
