R56 OEM xenon projector conversion with auto level sensors from salvage
Old Mar 22, 2024 | 06:52 PM
HAMnMINI's Avatar
HAMnMINI
I've found a similar model year R56 at a local junkyard that I'm going to attempt to salvage the projectors from. Is there any advice you guys have for me regarding what additional components I need to pull?
If I understand the diagrams correctly, I'm pulling the complete projector assembly with connected ballast and control unit. What I'm unsure of is the auto level sensors which are apparently mounted to the driver side control arms? How hard is it to access these and the associated wiring harness?
Old Mar 23, 2024 | 04:41 AM
Yoshimura 1's Avatar
Yoshimura 1
There's also one in the rear as well......not hard to remove though..... you need to figure out the harness situation.....
then you definitely need some coding......
Old Mar 23, 2024 | 10:48 AM
HAMnMINI's Avatar
HAMnMINI
Is it possible to get the harness? Looks like it’s the WHOLE harness.
I wonder if there an aftermarket connector just for the sensors.
Old Mar 23, 2024 | 11:10 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I can’t imagine you NEED the level sensors. Just dial in the alignment after install.
Old Mar 23, 2024 | 08:51 PM
HAMnMINI's Avatar
HAMnMINI
Is it possible to make them work without the xenon harness though? I can't find the schematics for the auto level sensors so Idk where to start
98oilhead
May 9, 2016 11:02 AM
djdellaquila
Jul 7, 2014 02:09 PM
Carmichael
Electrical
Feb 25, 2014 05:28 PM
Diezzler
Electrical
21
Sep 10, 2013 09:19 AM
Popozuda7
Electrical
35
Jul 30, 2010 07:57 AM
