R56 Does oil filter housing leak onto downpipe?
Old Mar 12, 2024 | 08:01 PM
Gabe3's Avatar
Gabe3
I've got a oil leaking running down onto my downpipe. I think its the oil filter housing because I think the leak is coming from above the oil pan. Is this typical for oil filter housing leak?
pic: https://imgur.com/a/2xe6LwN
Old Mar 13, 2024 | 02:48 AM
Yoshimura 1's Avatar
Yoshimura 1
Well.......they do tend to leak you have 2x sets of gaskets in that housing......better pictures would also help!
Old Mar 13, 2024 | 06:43 AM
Yep down the front on the engine. Looks near the downpipe further up on the block. If its just the bottom, its the oil pan gasket.
Old Mar 19, 2024 | 06:36 PM
Gabe3's Avatar
Gabe3
Thanks, I started removing the oil filter housing today but not sure how to remove it from the car. Theres a pump(not sure if its actually a pump) mounted to the housing with a electrical plug connected, any idea how to unplug it? Or should I remove the two bolts that are mounting it to the housing?
Old Mar 20, 2024 | 05:45 AM
Yoshimura 1
There's a couple of torx's bolts that secures the oil filter housing to the engine block......
When I replaced my gaskets I put the front into service mode.....this allowed me too easily
remove the housing and clean the area......the downpipe shield is blocking one of the coolant
lines.......
broncobuddha
Oct 24, 2017 11:11 AM
one73ronin
15
May 24, 2015 09:13 PM
fenderpicks
Nov 4, 2014 03:47 PM
K9MINI
May 2, 2014 08:09 AM
Dizzy_Jenny
17
Oct 17, 2007 08:02 AM
