R56 n18 Timing chain guide and valve stem seal
Hello,
Just started on replacing timing chain and guide, as well as valve stem seal.
This is to record the steps of what I've done.
Here is the list of parts and special tools I've used.
Parts
11667610690 Vacuum pump gasket
13517528408 HPFP gasket
11287604014 Serpentine belt
11287571015 Tensioner pulley DAYCO 89161
11127582400 Valve cover gasket
11217616164 Crank pulley bolt
11117568263 Crank shaft seal
11217588996 Crank sprocket
11367536087x2 Camshaft bolt
11318618318 Timing chain
11317577631 Upper guide rail
11317577301 Guide rail
11317533879 Chain tensioner guide rail
11317534768x2 Guide bolt
11317534771 Guide bolt
11317607551 Chain tensioner
11340033950 Valve stem seal
11341438142 Valve collet -> if necessary
Tools
N18 timing tool kit
N18 serpentine belt tensioner tool
Valve spring compressor tool
Cylinder leak down tester
Torque wrench that can go down to 10NM.
Day 1.
Removed intake and intake tube
Removed U brace/support
Removed ignition coils and spark plugs
Removed valve cover
Removed intercooler charge pipe
Parts
Tools
N18 timing tool kit
Day 1.
Removed valve cover
Thanks for documenting this. I am about to dig into the valve seals myself. I have all the tools, just need to find a few days to spare.
Let us know if you hit any snags. I know there are some great videos out there. I am curious how you deal with the intake cam springs, the 2 long videos on Youtube each do it differently.
Good Luck!!
Good Luck!!
When I bought this car 2 years ago, I replaced valve cover gasket, and the internals look the same as now, so it could be the previous owner who wasn't on top of oil changes.
Good Luck!!
Good Luck!!
Day 2.
Installed flywheel locking pin and cam timing locking tool
Removed intake side Vanos
Removed timing chain tensioner
Removed serpentine belt
Removed crank pulley
Removed engine mount and support bar
Removed friction wheel and belt tensioner
Removed top chain guide
Removed 2 cam gears
Removed 3 tensioner guide pins
Removed timing chain and guide -> the car ran fine before, but VERY surprise to find the guides were broken already. I was really running on borrowed time.
Removed crank seal
Uninstalled cam timing locking tool
Removed 2 cam gears
Removed crank seal
No kidding. Totally didn't expect that. The car ran fine prior to removal. It was on its last leg.
Day 4.
Replaced valve stem seals
Installed eccentric shaft and camshafts
Installed cam timing locking tool
Installed new timing chain
Everything went pretty smooth. All screws are hand tightened for now because found that my torque wrench only goes down to 20NM.
Ordered new torque wrench from Amazon.
The tool I used.
And this is how I did.
Also used this youtube video.
Day 5.
Installed HPFP
Installed vacuum pump
Installed friction wheel and belt tensioner
Installed crank pulley with new crank seal
Installed serpentine belt
Installed engine mount and support bar
Performed timing
Installed timing chain tensioner
Installed intake side Vanos
Installed valve cover with new gasket
Installed ignition coils and spark plugs
Installed intercooler charge pipe
Installed intake and intake tube
Tomorrow is big day!!!!
Installed HPFP
Performed timing
Actually. Not bad at all. The first one is always tricky, but after that, quickly learned how to do it.
The tool I used.
https://www.youtube.com/watch?v=N-VyHMq4vQc
The tool I used.
I saw few videos on how to use the spring tool, and looked very complicate. Now I've done it, definitely think the modified screwdriver method is easier and quicker.
Day 6.
Install U brace/support
Fill the coolant -> was drained because I had to replaced a coolant pipe.
Reset variable valve timing adaptation
Knock on wood and fire her up.
YES. She is running well and NO CEL. Fxxk YEAH!
I'll drive her around for a couple of weeks and change the oil.
Here is the video of her running!
I'm so glad it's all finished without any major hiccups.
I've been driving last couple of days and noticed the engine sound have changed. It could be placebo, but sounds more smooth.
R56 timing chain advice wanted
I've got a 2012 R56 Mini Cooper (not turbo) with about 90,000 miles on it. I've been told by my local mechanic that I ought to be thinking about replacing the timing chain. Does anyone have any advice as to what's typically accepted as the recommended mileage for this maintenance?
TIA
TIA
TIA
TIA
You should look into it very soon.
TIA
TIA
cpmetz
03-26-2019 01:17 PM
