R56 coolant leak source and expansion hose replacement
Old Mar 5, 2024 | 10:30 AM
  #26
We have a lifetime replacement on the parts. I been running the bremmen for a long time. Since 2021. In fact when Genuine MINI was on Back order world wide for the market we were the only ones whom had an aftermarket solution and we had shops and dealerships buying ours for down cars. I drove the last Genuine MINI n14 thermostat before it went Back order a couple years ago to a local MINI dealer to help a down car. I dont know what ever happen to that MINI but the local dealer here was happy.
Most of the time when they leak its from improper install of the rear gasket to the waterpipe.
Behr-mahle made some for a while dependent on version and sku and so did Markiv Automotive france (dayco france). Markiv Automotive france does not really sell into aftermarket under that brand. Seems like they are a exclusive contract like Mecaplast is for MINI and PSA valve covers. They have an exclusive and don't sell direct unless its the MINI dealer or PSA dealer under the Genuine MINI and PSA brand.
Hope that helps.
Old Mar 10, 2024 | 08:48 PM
  #27
HAMnMINI's Avatar
HAMnMINI
I am running our bremmen parts thermostat and the ECS metal water pipe.
My Genuine MINI thermostat went and leaked onto my transmission. It had a hairline crack and when the car go warm it would leak.
with the new thermostat the old sensor on the metal pipe is redundant. do you know what the part number is for the new hose? is it 17122754221?
Old Mar 10, 2024 | 08:51 PM
  #28
HAMnMINI's Avatar
HAMnMINI
also, has anyone found a good longer alternative to the expansion tank return hose?
I tried the dayco gold label heater hose from advanced auto and it’s too stiff to be tucked in.
considering trying thr duralast one from autozone. it was more flexible.
Old Mar 10, 2024 | 11:11 PM
  #29
HAMnMINI's Avatar
HAMnMINI
what is the circled pipe? it is connected via a t-joint to the upper radiator hose. it’s not listed in the diagram so part number would be appreciated!
Old Mar 11, 2024 | 03:49 AM
  #30
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Your car is an automatic. That is the transmission cooler supply hose, item #3:
https://www.realoem.com/bmw/enUS/sho...diagId=17_0393
Here:
https://www.ecstuning.com/Search/Sit...h/17122754222/
Old Mar 11, 2024 | 07:18 AM
  #31
HAMnMINI's Avatar
HAMnMINI
Here:
thank you! I found it just before falling asleep but wow those diagrams are confusing. the way it’s drawn it looks like thats a whole different hose instead of the alternative for automatics.
Old Mar 11, 2024 | 08:01 AM
  #32
Yep you also are a year and model that has that old elbow.
https://www.northamericanmotoring.co...t-leaking.html
https://www.northamericanmotoring.co...lant-leak.html example.
Thats the one https://www.ecstuning.com/Search/Sit...h/17122754221/ to remove that elbow piece. https://www.realoem.com/bmw/enUS/sho...93#17122754221
mgmblitz
R55 :: Clubman Talk (2008+)
Jun 12, 2021 07:39 AM
Colin Schlagel
Apr 29, 2021 07:59 AM
Cngizbleevng
Jan 16, 2021 06:34 PM
BigGar
Apr 24, 2017 05:17 PM
lasher10
Apr 10, 2017 05:05 AM
