R56 P2188 too rich at idle
Old Feb 22, 2024 | 04:56 PM
Rusty12's Avatar
Rusty12
So I know this has been gone over a lot but I’m stumped. Bought the car 2007 Mini Cooper S with the check engine light on and was told it was the o2 sensor. Since then it has broke a valve so I have replaced all the valves and stem seals, but done the walnut shell cleaning and both o2 sensors are new. New MAF sensor and new fuel injectors and plugs and coils. It runs beautifully but still has that same code. I’ve checked for induction leaks and exhaust leaks. And it is rich as the tail pipes are black. No smoke though
Any ideas.
Thanks in advance
Old Feb 24, 2024 | 06:38 AM
Rusty12's Avatar
Rusty12
Anyone, anyone? Buhler?
Old Mar 9, 2024 | 05:12 AM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
Retrieving the BMW fault code should help you pinpoint the cause.
Old Apr 27, 2024 | 10:52 AM
07 Mini R56 JCW's Avatar
07 Mini R56 JCW
I have the same car, same P2188 problem. What check in Bimmerlink will help find the problem? I cant register mine until CE is off.
07 with141k
I need something better than Bimmerlink. It wont show sensors page nor dashboard, just a message telling me to "retry" What is better? I use Veepeak OBD2
Old Apr 27, 2024 | 11:03 AM
Maybe, maybe not
Community Builder
Pull the BMW code to help pinpoint the precise problem.
https://bmwfault.codes/
Old Apr 27, 2024 | 11:47 AM
07 Mini R56 JCW
Aha!! Will BimmerLink give me that detail beyond just P2188. Ill go see right now, if I can get it to connect.
edit: nope. returning VeePeak and Bimmer. getting a real scanner. Foxwell.
Old Apr 27, 2024 | 06:34 PM
mkov608's Avatar
mkov608
Rusty, I'm normally an R56 guy, but recently found a distressed R53 that had been sitting for 2 years. I picked it up cheap, and got to work. I installed the 15% reduction pulley and the Chinese version of the 380cc fuel injectors. The check engine light came on and I was running rich. I connected my scan tool and found my total fuel trim was -30. I talked to the very nice folks at Way Motor Works and the young lady said those Chinese knock-off injectors don't spray right; they won't even tune the car if those injectors are installed. So, I put the original 330 CC injectors back in, and the problem was solved.
What injectors did you install?
How many gram/sec are you seeing at idle from the MAF sensor?
Pull up your upstream O2 sensor current on a scan tool; add propane to the intake and make sure the O2 is going rich (negative current number).
yyj3869
Dec 19, 2018 01:16 PM
wsdivall
May 29, 2018 12:19 PM
MiniCooper_S
Aug 3, 2017 01:27 PM
bearcat245
Jul 10, 2014 04:40 PM
cdutton69
Dec 28, 2012 08:52 PM
