R56 Excess cam retard code
Hi, 2009 non turbo 110k miles. Actually got the cam retard code and all cylinders misfire code.
Could this be a dirty VANOS solenoid? Looks to be one of the easier repairs, anyone do this repair proactively?
Codes cleared after a few restarts (I did use scanner but did not write down actual code) but search tells me it was likely P0015 B Camshaft Position Timing Over-Retarded Bank 1.
I have seen people suspect camshaft chain stretch but because it was accompanied by all cyls also reporting misfire I think cam went way out of time momentarily.
My wife was driving and did not report any engine hesitation but she probably would not notice a momentary issue.
I'll wait and see if it happens again.
Make sure you post all of the codes when/if it comes back.
Codes in memory will not clear after a few restarts; the check engine light may go out after a key on/off cycle, but the codes are stored in memory. Code will only clear if you've erased them with a scan tool.
I've had the 2DXX whatever code pop a couple of times on my 2011 MCS and bought a replacement solenoid to address it on the exhaust side, but I couldn't get a start on the darn Torx bolt and didn't want strip it. However, I was trying T25 and T30 and I believe it's a T27, which I now have, so maybe one day I'll try again. At least the exhaust side is somewhat accessible. I also tried the connector on the intake side to see if I could get it to unclip for future needs as it's upside down and gave up after frustration built.
The code has always disappeared on a restart, so I haven't been too bothered - yet.
cheers
MacMini34
tway
Aug 14, 2016 06:08 AM
