R56 Parking light error
Parking light error
Hi, I have a problem with my Mini Cooper S R56 2011 European - one parking light (right) doesn't work and an error is generated. I have replaced the bulb - didn't help. The bulb is good, checked it. The connector looks good, no sides of corrosion or something similar. Checked cables but all looks fine. Found out that there's no separate fuse for these parking lights, maybe some relay is broken? Where should I search for solution? Can't find electric diagram anywhere. Please help
Test with voltmeter, i bet their is a break in the socket or the socket is bad. Have a picture of the socket?
There's no voltage in the socket since there's an error, even with new bulb. I have an idea that the error happened too many times and for too long and the light control module need to have the error counter reset, is this the right thinking process?
You can try the reset.
eljay
R60/R61 Stock Problems/Issues
Sep 2, 2022 09:01 AM
mtbscott
Oct 9, 2006 06:06 PM
