R56 Sway bushing and link questions
Old Jan 8, 2023 | 12:38 PM
redwhiteR562007's Avatar
redwhiteR562007
2007 R56 Hatchback
I need to replace my sway bar bushings front and rear and figure I just as well replace the sway bar links at the same time.
I searched Pelican parts for bushings and found:
-- Rear sway bar bushings in 16mm and 18mm size
-- Front sway bar bushings ranging from 21.5mm to 24mm.
I assume this is the DIAMETER OF THE SWAY BAR. Short of crawling under the car with a micrometer, how do I tell what size bushings I need, front and rear?
The difference in sway bar LINKS seem be only front and rear, no difference in length.
Old Jan 8, 2023 | 03:53 PM
takrdown's Avatar
takrdown
Really depends on if you have a "COOPER" "COOPER S" or "COOPER S JCW" and what package is installed on each:
COOPER
FRONT:21.5 mm
FRONT w. SPORT Package 23.5 mm
REAR 16.0 mm
REAR w/ SPORT Package 18.0 mm
COOPER S
FRONT 22.5 mm
REAR 17.0 mm
JCW
FRONT 24.0 mm
REAR 18.5 mm
If you're unsure if your car came with the sport package, you can probably google a VIN decoder and I think it will be listed in the options. Good luck!
Old Jan 8, 2023 | 04:40 PM
redwhiteR562007
THANK YOU!!!! That's exactly what I needed -- not a Sport, just a plain ol' Cooper driven for 120,000 miles by a couple of old white-haired people in our late (very late) 70's!!
jeangtd
Jun 16, 2020 03:39 PM
CSP
Jul 31, 2017 01:54 PM
66stang21
Suspension
Sep 10, 2016 08:49 PM
bonusbulldog
Suspension
Jan 22, 2010 09:35 AM
Iautox
Suspension
Oct 1, 2007 11:29 PM
