R56 Cyl 1 misfire
Old Dec 12, 2022 | 01:05 PM
redwhiteR562007's Avatar
redwhiteR562007
Cyl 1 misfire
2007 R56 hatchback 120,000 miles
CEL on, running rough. Code shows Cyl 1 misfire
Pulled the plug, looks normal -- plugs were new at 102,000 -- pulled the other three plugs to compare with #1, all look the same as far as carbon buildup. No oil fouling.
What next?
And if it's $2,000 I'm handing the title to the dealer and tell him it's all his.
Old Dec 12, 2022 | 01:28 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Try swapping coils around, see if the misfire moves. If misfire moves, new coils and plugs. Plugs should only cost ~$10 each. Wouldn't cost much to just throw new plugs in it regardless. New set of coils would be ~$100. Swapping coils around would only take 10 minutes.
Old Dec 12, 2022 | 01:38 PM
thmpr464's Avatar
thmpr464
Check the fuel trim and AF ratio. Could possibly be the fuel injector. I hope it is not the dreaded crankshaft pulley.
Old Dec 13, 2022 | 11:40 AM
redwhiteR562007
YOU ARE A GENIUS!!!!!
My code reader showed MISFIRE CYL 1. I erased the code, swapped the coils between 1 and 3, CEL came on, code reader said MISFIRE CYL 3 !!!!!
Just ordered 4 coils and 4 plugs.
THANK YOU!!!!!!!
MERRY CHRISTMAS!!!!!!
Old Dec 14, 2022 | 01:28 PM
redwhiteR562007
New plugs and coils arrived for Rock Auto, took about 10 minutes to install new plugs and coils, Cooper is running like new!!!!
Thanks!!!
Old Dec 15, 2022 | 03:30 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Thanks!!!
Old Dec 20, 2022 | 10:03 AM
joseph.pokorski@gmail.com's Avatar
Congrats on fixing the misfire. With 120,000 on the clock, might be time to budget for a walnut blast of the intake valves, if the misfire returns. Three hours labor.
Ahmed Hisham
Jan 10, 2023 12:57 PM
O51R15
Jan 23, 2018 05:37 PM
seamusnh
Mar 14, 2016 07:43 AM
blakeslee_a
Dec 26, 2012 04:56 PM
Bishopthomas
Mar 23, 2012 06:01 AM
