Does anyone have advice on getting the OE water pump gasket to stay put in the water pump gasket groove? The OE gasket pops out when I push it in. I figure there's some adhesive trick, but hoping someone who's used the combo can help.
If I can't get it, I plan on using the gasket that came with the pump, that's thinner but stays put just fine.
Thank you! For whatever it's worth to someone who ends up here. The above to use the gasket that fits snuggly was good advice.
That said, Mini seems to have updated this gasket design a bit. You can see how in my original picture, there are more retaining bumps. That's the one I got from mini. I was curious, so I bought one of the Elring gaskets, which looks like the gasket pictured online everywhere. It has fewer retaining bumps, but it fit and stayed put on my pump without issue or the need for applying grease. Here it is from ECS
