Drivetrain Misc. Parts for Supercharger\Water Replacement?
Old Dec 31, 2016 | 07:44 AM
AlbertCL's Avatar
AlbertCL
Hi, a questions for those of you who have swapped out your supercharger and water pump:
1. Are there any miscellaneous parts needed that are easy to overlook?
I will be purchasing a supercharger, water pump, belt and pulley. Do I need an additional gasket to connect SC to pump, etc? I'm aware that I will need the belt tensioning tool and puller for pulley.
2. Did you use anti seize or thread lock? If so, what kind?
Albert
Old Jan 15, 2017 | 06:17 PM
AlbertCL's Avatar
AlbertCL
Hey everybody, I'm attempting the swap out this coming weekend. I'm still looking for feedback regarding what type of anti-seize is recommended. Please let me know.
Albert
Old Jan 15, 2017 | 06:35 PM
*CharlieHustle's Avatar
*CharlieHustle
Albert
When I changed out my water pump and serviced my supercharger, I also purchased the water pump flange that bolts to the block, intake to supercharger gasket, throttle body gasket, water pump outlet to pipe hose, and the supercharger to intercooler outlet gasket.
I dont recall using anti seize or thread lock anywhere when putting everything back together.
Old Jan 15, 2017 | 06:41 PM
AlbertCL's Avatar
AlbertCL
Thanks for the info. I have everything you mentioned on order except for the throttle body gasket. Is that necessary?
Old Jan 15, 2017 | 07:12 PM
*CharlieHustle
For the cost of the gasket, I went ahead and replaced it since the throttle body was removed from the car. I have 143k miles on my R53 so I wasn't sure if the original gasket would seal when it came time for reassembly. You might get away with re-using the old gasket, but it's suggested to replace it once you've broken the original seal.
Old Jan 15, 2017 | 07:13 PM
AlbertCL's Avatar
AlbertCL
I went ahead and purchased one. Thank you.
