R57 In-Tank Fuel Pump out?
Old Nov 23, 2022 | 05:44 PM
SamKay's Avatar
SamKay
I have got an issue with the LPFP. After looking at a few replacements online, I found some fuel pumps not as a fuel pump assembly but rather the pump “motor” itself. Does anyone know how to remove the fuel pump out of the fuel pump assembly?
Old Nov 26, 2022 | 12:23 PM
RockC's Avatar
RockC
Right up front no I do not know.
It may not even be possible.
Old fuel pump from my Boxster:
After I got the housing off...
New fuel pump...
You will note how aged the plastic housing is. And the hoses. The risk is even if the housing can come apart due to age you might break something. Also, not pictured but the bottom of the fuel pump housing is the fuel filter. It is a fine plastic mesh. While it wasn't that bad the mesh had some amount of particulate matter trapped. This was after around 200K miles of use. Still with a new pump and its housing and new fuel hoses/lines/connectors you run less risk of one of those items failing. So my advice is even if you can get the housing apart and remove the pump proper and replace it with a new one you probably shouldn't. You should replace the entire fuel pump assembly, the housing with its new hoses/connectors/etc and be done with it.
MidwayMountaineer
Jun 27, 2022 07:39 AM
imaslowdriver
Nov 23, 2020 12:03 PM
jeffm5150
Classic Mini Talk
Apr 3, 2012 04:21 AM
TwOMINIs
Sep 1, 2007 06:59 PM
early_apex
Off-Topic :: Autos
Aug 31, 2005 10:09 AM
