R56 Liqui Moly Engine Oil & Cera Tec
Old Oct 16, 2022 | 01:48 PM
airbusA346's Avatar
airbusA346
On my 2012 R56 Cooper S when it has had oil changes I've used Castrol Edge 0W-30 or 5W-30.
The car is due an oil change and my plan is for it to be done when I get the JCW spec turbo fit and numerous other mods.
I've been looking at Liqui Moly. I've never used it before so contacted Liqui Moly to ask what they suggest I use. They suggested using Leichtlauf High Tech 5W-40 and Cera Tec. They also recommended using their Pro-Line Engine Flush.
Has anyone used this combination, especially the Cera Tec?
The car has done 53,000 miles. It is to be used for fast road/track/Nordschleife Touristenfahrten, but also needs to be able to be used on a daily basis if/when required (even during the winter). Plan is for it to be around 250bhp when the turbo is fitted.
Old Oct 17, 2022 | 11:37 AM
Gubi's Avatar
Gubi
Dunno about the oil, but I would NOT use engine flush.
The thing about engine flush is that if you don't have any significant sludge, you don't need it. But if you *do* have significant sludge, the flush can break it free, plug up your oil pickup, and kill the engine. The latter happened to a buddy of mine on his Miata.
If you've got sludge in the engine it needs to be either left alone or cleaned out properly IMO.
Old Oct 18, 2022 | 08:48 AM
Tigger2011's Avatar
Tigger2011
Alliance Member
Ligui Moly is good stuff. If you want to flush the engine safely just follow the directions on a can of sea foam. Put it in the oil, drive for 10 minutes and drain the oil. I do this every third oil change. Got 90,000 miles on the wee beastie and he only uses 100cc of oil between changes.
Old Oct 18, 2022 | 08:55 AM
airbusA346's Avatar
airbusA346
What's the difference between sea foam and Liqui Moly type engine flush?
Old Oct 18, 2022 | 10:12 AM
Tigger2011's Avatar
Tigger2011
Alliance Member
About $10.00 in your wallet
maarp
Aug 22, 2021 09:46 PM
jmgpr7
Nov 9, 2012 03:59 PM
mbwicz
Mar 12, 2012 12:25 PM
JCW11
Factory JCW Talk (2009+)
Jan 17, 2012 07:23 PM
marcin001
Jan 2, 2011 05:13 PM
