R56 Parts advice requested
Old Aug 25, 2022 | 09:19 AM
TuaLaoch's Avatar
TuaLaoch
I'm getting misfires on cylinders 1 and 2 and the unmetered air code. This car has been nothing but trouble and I'm tired of sinking money into it. I think I want to try replacing the Vanos solenoid. Is there a good aftermarket alternative to the OEM solenoid? If I can get rid of the code and misfires, I'm just gonna sell it and move on. This car (2010 MCS auto) is driving me crazy!
Old Aug 25, 2022 | 10:04 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
The "Unmetered Air" code means there is a leak at the manifold. On a 2010 Cooper S with an "Unmetered Air" code, my first check would be the PCV tube that goes between the cam cover and the intake manifold. They are made from a flimsy, cheap plastic that gets brittle with age, and can crack and leak. The leak can be VERY hard to diagnose because of the tubing routing. You can remove it, then check it very carefully for any cracks. The replacement part is cheap enough to just get it and replace it:
https://www.ecstuning.com/Search/Sit...h/11157605186/
Old Aug 25, 2022 | 10:06 AM
TuaLaoch's Avatar
TuaLaoch
This is the vent hose on the rear passenger side of the engine, correct?
Old Aug 25, 2022 | 10:14 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Yes, rear passenger side of the cam cover, and it snakes down below the intake ports and connects to the lower drivers side of the manifold.
Old Aug 25, 2022 | 10:18 AM
TuaLaoch's Avatar
TuaLaoch
That's about the only thing I haven't replaced, so far.
Old Sep 2, 2022 | 12:43 PM
TuaLaoch's Avatar
TuaLaoch
Does anyone know the best place to connect a smoke machine for finding vacuum leaks on this car? Thanks!
ThatPepperWhite
Jan 17, 2021 03:24 PM
Warren2185
Oct 24, 2020 10:42 AM
silkcut
Jul 18, 2017 02:32 PM
howieschoon
Aug 2, 2015 12:06 PM
sickboi55
14
Mar 2, 2014 03:47 PM
